Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-03-2003, 10:47 AM   #1
rogeryung
Member#: 17803
Default front diffential question on 2002 OBS
I have a A/T and I want to change the tranny fluid and the front and rear differentials. Does anyone know what size socket or wrench I need to loosen the front diffential plug? I've read that a 1/2" ratchet works on the rear diffential, does that work on the front as well? If so, I also heard it isn't an exact fit. I worry about not getting the plugs tight enough if there is some play between the socket wrench and square plug. I don't want to strip it.
Thanks
rogeryung is offline   Reply With Quote
Old 09-05-2003, 09:52 AM   #2
rogeryung
Member#: 17803
bump. anyone?
Idle Question on 2000 OBS Richard1296 Normally Aspirated Powertrain 0 12-11-2006 08:42 PM
Locating the clutch slave cylinder on 2002 OBS karst Service & Maintenance 1 09-29-2006 08:12 PM
Need to replace front rotors/pads on 2002 OBS - Need Advice! mekkon Brakes, Steering & Suspension 6 04-24-2006 07:16 PM
('93-'01) Safety Question on 98 OBS Jejunum Impreza Forum 4 09-09-2003 01:29 PM
19" rims on 2002 OBS? Pillage Brakes, Steering & Suspension 10 09-22-2002 01:56 PM
