Old 09-03-2003, 01:04 PM   #1
DDub
Member#: 7634
2006 LGT
g'bye 00 RS
Default Rear diff shot
I took my 2000 RS in for a whirring noise when under acceleration and they diagnosed it as a bad rear diff. Said they also have to replace the "drive shaft", but he might have meant half shafts the way he was talking.
I thought this was interesting as I remember people on the board saying the rear diff was pretty indestructible. The service mgr also said it was a rare thing to go out. Rare enough that the parts had to be special ordered. I will try to talk to the actual subaru tech when I bring it back in for the service. AFAIK, this will all be covered under the drivetrain warranty.
More updates when I get the diff replaced...
*edit* This is all with stock power, no rallying or tracking the car, etc.
DDub is offline   Reply With Quote
Old 09-03-2003, 01:08 PM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You think that's bad, I blew the center diff
Its not that uncommon, sucks, but it has happened before.
Old 09-03-2003, 02:14 PM   #3
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
must of been faulty....
unless you pull the U-brake a lot!!
trojan9x is offline   Reply With Quote
Old 09-04-2003, 11:02 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Can you provide any more details on the symptoms and diagnosis? I know when my center diff went I posted a bunch of info for folks to use (no idea where the thread is).
Old 09-05-2003, 01:03 PM   #5
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I know someone who thought they had a bad rear diff too, turned out to be a wheel bearing and an axle.
AO
m750 is offline   Reply With Quote
Old 09-05-2003, 05:31 PM   #6
DDub
Member#: 7634
2006 LGT
g'bye 00 RS
Well, the service manager initially said it was a wheel bearing, but then called back and said 'rear diff and drive shaft' were bad. Wheel bearing is usually noticable as a different sound when turning, right? This is definitely drivetrain as it is very noticable when the drive train is loaded (as in accelerating or maintaining speed) and the sound almost totally goes away when decellerating.
Before I took it in I could have sworn it was coming from up front and thought it was transmission or wheel bearing.
I should hear from them re: parts arriving next week.
Old 09-05-2003, 06:48 PM   #7
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Do u have aftermarket suspension like shocks and springs?
If you do, will warranty cover it still?
Mirage is offline   Reply With Quote
Old 09-05-2003, 10:24 PM   #8
jkyes
Member#: 707
99 Legacy GT
Quick silver
yes they can not void warrenty due to normal aftermarket additions like struts and springs.
if they give you any trouble put up a big fight, everything i have read and seen says they can not void a warrenty for anything like this.... of course depending on milage.
jkyes is offline   Reply With Quote
Is my rear diff shot? BKscooby Newbies & FAQs 6 01-19-2010 10:36 AM
Is my rear diff shot? arf80 Transmission (AT/MT) & Driveline 3 09-30-2008 08:32 PM
How can I tell if my rear diff is shot. rs6er Transmission (AT/MT) & Driveline 1 12-01-2006 04:01 PM
wtb: shot in the dark......superpro rear diff bushings poopooscrum Private 'Wanted' Classifieds 1 08-30-2006 04:01 AM
Rear diff protector & shot shifter q's Rallytime WRX Forum Archive 1 02-20-2001 06:37 PM
