Old 02-19-2001, 09:57 AM   #1
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Question how do you change fog bulbs on an MY00 RS?
havent looked yet, is it the same kind of holding mechanism as the headlight bulbs? my Hella yellowstar 85w fog bulbs should be here today.
thanx,
justin
joostin420 is offline
Old 02-19-2001, 10:22 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
hey, you can just take out the whole assembly via 3 screws. Once you have the fogs off, it'll be easy to do. I haven't exactly checked myself, but since they are a different style bulb, the way they're held in there will be different, too. Again, since you can take the whole light assembly out, you'll have easy full access to where the bulb goes in, so it shouldn't be tough.
JGard is offline
Old 02-19-2001, 11:20 AM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yep, 3 screws (don't touch the one that looks different, that one's for the beam adjuster), remove light, disconnect harness, twist & remove cap on back, unplug bulb terminal, push down on metal bulb retainer, remove bulb (DON'T TOUCH THE BULB GLASS), repeat backwards with new bulb.
RidinLow is offline
Old 02-19-2001, 11:20 AM   #4
SilverSuby
Member#: 1599
2000 Impreza RS
Post
It's actually very simple. The are just H3 bulbs, very similar to the headlights. The three large screws will take out the whole assembly, then you just unfasten the little wire on the back of the bulb. You'll know what I mean once you get the assembly off.
SilverSuby is offline
Old 02-19-2001, 12:29 PM   #5
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Question
thanx guys, just did it on my lunch break. so who has the yellowstars 85w, and are they really yellow/yellow light? are they very bright at night, and do they make a big difference in inclement weather?
thanx,
justin
HTML code is On
How do you get fog lights on with parking lights on only... Phreaker Impreza Forum 10 01-30-2008 04:03 PM
How do you remove Crank Pulley on an AT? EdHilario Normally Aspirated Powertrain 26 09-16-2007 10:59 PM
How do you change the fog liht bulbs on a 04 wrx? eshtog Interior & Exterior Modification 2 07-23-2004 11:51 PM
04 REX how do you change the fog lights? kitbar Interior & Exterior Modification 2 04-13-2004 12:38 AM
How do you change the WRX parking light bulbs? YeeHa Interior & Exterior Modification 5 02-03-2002 06:06 AM
