Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 09-04-2003, 04:58 PM   #1
BrokenCrank
Member#: 42682
2000 Legacy Outback
Blue w/4EAT
Default How about swaybars?
Anyone put larger bars in their Outback. I see whiteline has a rear bar, but no listing for a front.
Any other manufacturers I should look at?
Thanks,
Crank
BrokenCrank is offline   Reply With Quote
Old 09-24-2003, 06:44 PM   #2
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
I put a larger bar on the rear of my Outback H6. Certainly helped make it understeer less.
SubaH6 is offline   Reply With Quote
Old 10-15-2003, 07:37 AM   #3
rubberman
Member#: 28881
2005 LGT wagon
BSM Stage 2.5
Post
I just looked up the Whiteline website yesterday - they did have both front & rear sway bars in several flavors, from mild to heavy duty.
Check the website, there's an application pdf on there - page 20 for subarus.
Wes
rubberman is offline   Reply With Quote
Old 10-16-2003, 09:41 PM   #4
BrokenCrank
Member#: 42682
2000 Legacy Outback
Blue w/4EAT
I have purchased and installed sways, end links, strut bars, and springs... nearly everything in the Whiteline catalog, since my original post.
As an FYI, the rear strutbar listed in the Whiteline catalog does not fit the BH chassis, nor do the 70366 front springs! I am awaiting resolution of the spring issue...otherwise it is back to stock!
Old 10-17-2003, 07:58 AM   #5
rubberman
Member#: 28881
2005 LGT wagon
BSM Stage 2.5
Question
Sounds like you have a pretty nice ride now!
Any possibility of pictures?
Also, I am curious to know your impressions of the parts you swapped - did the handling increase that much?
Much of my dissatisfaction w/ my Outback is the huge amount of body roll - intend to swap rear sway bar to take care of that.
Any other suggestions based on your setup and could you list in order of importance which components you would replace first if you had it to do over again?
Hope the springs get resolved soon.
thanks for any info.
Wes
Old 10-18-2003, 06:49 AM   #6
BrokenCrank
Member#: 42682
2000 Legacy Outback
Blue w/4EAT
Wes,
There are a couple decent size pics in the Legacy forum...look for "Whiteline'd BH wagon" (or something to that effect).
I first installed the rear 20,22,24 bar with the regular endlinks, and set it to the "24" setting. This helped the body lean quite a bit!
The springs actually lowered the car more than the advertised 30mm (more like 45 in front and 40 in the rear), and caused a marked improvement in cornering force, and much less body lean.
The problem I am working on with Whiteline, is that the U.S. Outback (2000+) apparently has different springs than the rest of the planet! We have a spring with a cylindrical shape, while other markets have a spring whose diameter decreases near the top. The springs are listed as '99+ compatible, but are definitely not meant to be on my car! There is another part number that will supposedly fit, but it is sounding like I will have to wait for over a month to get them...
Old 11-06-2003, 08:21 PM   #7
Mat
Member#: 46511
1997 Outback Ltd.
Black/Tan
Interesting. The cone shape indicates that it's a progressively-wound spring, rather than our cylindrical linear-rate springs.
Mat is offline   Reply With Quote
Old 12-02-2003, 09:09 AM   #8
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Old 12-09-2003, 10:01 PM   #9
bat1161
Member#: 11878
2006 3.0 H6 Wagon
BrokenCrank,
When you first replaced the rear sway bar, did you do the end links at the same time, or did you wait? Also, did you order directly from Whiteline or did you find a distributor. I'm looking to cut down on the body roll only.
Thanks ,
Mark
bat1161 is offline   Reply With Quote
Old 12-10-2003, 10:13 AM   #10
black H6
Member#: 48887
2003 outback H6
black
what kind of swaybar do you have?
black H6 is offline   Reply With Quote
Old 12-11-2003, 03:00 AM   #11
Cao Cao
Member#: 40685
2003 H6-3.0 Wagon
Titanium Monotone
Did you order these straight from Whiteline Australia? I can't find anyone in the states that sells Whiteline products for the Outback. Mine specfically being an H6-3.0 Wagon.
Cao Cao is offline   Reply With Quote
Old 12-11-2003, 03:32 PM   #12
BrokenCrank
Member#: 42682
2000 Legacy Outback
Blue w/4EAT
Default To the folks that want to know where...
I got my swaybars and strut braces from a local guy who had sold his 2000 Legacy GT (all but the rear strut brace fit my car). The springs were purchased through Carter Subaru ("Subiegal" from Carter posts here).
I installed the rear swaybar with the standard Whiteline endlinks. I skipped the front swaybar (sold it locally) as the rear bar and endlinks made the handling nearly neutral! The springs became a bit of an ordeal as the #70366 fronts do not fit my car. Whiteline was great, and sent me a set of #70198 front springs which fit perfectly and help the ride and handling tremendously!
If you go to Whiteline's site, they have a list of US dealers that can supply you with parts...
Old 12-27-2003, 02:22 PM   #13
legacy2003
Member#: 38338
2003 Outback Sdn H6
sorry to steal this thread but does anyone have a rear sway bar from a 95-99 legacy outback? im looking to upgrade my sway bar (15mm on legacy vs. 18mm on outback)... thanks!
-mike
legacy2003 is offline   Reply With Quote
Old 01-15-2004, 06:56 AM   #14
Rally Medic
Member#: 28249
1998 Outback Sport
i have a 22 mm on mine
OMG quick question about swaybars White2.5GT Legacy Forum 18 04-14-2004 07:46 AM
What to do about swaybars? ScreaminFast Brakes, Steering & Suspension 21 03-19-2004 10:28 AM
Educate me about swaybars SJwrx Newbies & FAQs 17 02-08-2003 12:48 AM
A Question About Swaybars for 98 Forester Ginseng Forester Forum 15 08-01-2002 01:01 AM
Stupid question about Swaybar (Help) ChrisWRX Brakes, Steering & Suspension 3 05-03-2002 07:07 PM
