Old 02-18-2001, 10:43 PM   #1
kaos200
Member#: 2692
Post Pinging! Octane questions...
Ping Ping Ping, Boom!
anyone have any approximate figures on how long/many/loud etc.. it takes for this to happen?
I was also wondering how badly each ping is to the piston(ej25 specifically)..
and what octane boost is best and how much octane is too much octane?
(Is too much bad?)
kaos200 is offline
Old 02-19-2001, 12:39 AM   #2
kaos200
Member#: 2692
Post
any thoughts?
[This message has been edited by kaos200 (edited February 19, 2001).]
kaos200 is offline
Old 02-19-2001, 04:33 AM   #3
PunksRS
Guest
Member#:
Post
Pings usually happen too fast to "count" if I understand your post correctly. It is sometimes hard to hear unless it is severe ping. It is easier to duplicate if you lug the engine. If you have never heard it before I'll describe the sound: almost like loose marbles in a container being shaken. Your car should not need octane boost if it is stock and you are using the recommended fuel grade. The beauty of newer technology and todays cars is that the ECU should detect ping and retard ignition timing controlling the ping. The last octane boost I used was in my Pontiac Trans Am with a 70 400 Ram-Air III that had 10.5:1 compression ratio. It was Moroso Octane Booster and it worked pretty good when I would drag race the car at Bandimere near Denver.
Punk
Old 02-19-2001, 06:57 AM   #4
SilverSuby
Member#: 1599
2000 Impreza RS
Post
What do you consider the recommended octane rating? The owners manual says use 87 octane, but with a 10:1 ratio I would suggest a higher octane. I read somewhere that we're supposed to use 91 AKI.
SilverSuby is offline
Old 02-19-2001, 01:12 PM   #5
kaos200
Member#: 2692
Post
we'll I'm definitaly not stock..
(turbo kit 7-8 psi right now)
and I tried NOS octane boost it helped actually...
I just need to know how long was it before any one lost a piston to pinging (preferably related to an ej25, but any advice will help)
kaos200 is offline
Old 02-19-2001, 01:16 PM   #6
98mpreziveRS
Member#: 972
Post
umm... from my own experiance the NOS if used repeadtly will eat your cats away ( i am assuming you still have A cat or 2. )
in my experiance i found the race formula to work the best, followed by the purple stuff ( dunno if you get it there...) a BIG BIG bottle good for up to 60 gallons IIRC..i was using a bottle a tank or a bottle every 2 tanks in the summer and i still use a bottle of NOS race every fill up that takes a big slice of money.. or when lazy i run 100 octane.
98mpreziveRS is offline
HTML code is On
Octane question--- 91 octane will hit $3 here Homerisking General Community 40 03-10-2005 11:50 AM
AccessECU Stage 2 93 octane questions... Hank3 Engine Management & Tuning 14 05-17-2003 05:03 PM
Gasoline octane question mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-14-2003 07:32 AM
California octane question.. silvercharged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-18-2002 03:57 AM
octane question spiralsmurf Normally Aspirated Powertrain 4 06-21-2002 01:42 PM
