#1 |
Member#: 2692
SCIC
Hello,
I can pretty much figure out it is for heat protection... but my BOV(I think that's what did it?) messed up all the fuzz! anybody take that off(as I did!) I need to know any side effects (paint wise ?) or anything else to replace it with? Thanks...
#2 |
Member#: 625
TXIC
Vehicle:2005 STi WRB/Gold |
It's not for heat protection, it's to put out an engine fire. At least that's what I was told. The little mounts would melt, that sheet of fuzz would drop onto the engine smothering the fire. Sounds reasonable in theory...
#3 |
Member#: 438
W. Canada
Vehicle:2004 STi White on Gold |
I think it also acts as sound deadening material.
#4 |
Member#: 2692
SCIC
anymore replies..?
#5 |
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
Vehicle:2000 Impreza Tanned - BRP |
I is in case of fire.
Nick. |
#6 |
Member#: 438
W. Canada
Not sue how effective it would be smothering fires since the air supply can just come from under the car?
#7 |
Member#: 1599
Vehicle:2000 Impreza RS Silver |
Who better than a fireman to answer this question.
It indeed could be to put out the fire, or at least slow it down a lot. It's probably some type of chemical that "steals" the oxygen from the fire, or maybe it's just designed to "smother" the fire. IF the fire is in your engine compartment, something must be burning. Fire cannot exist suspended in mid air[unless it's a gas], so it must be on top of some physical object. Many things in the fire prevention industry are weird. For example, we have a device which is a special flare. You light it and put it in a fire place and it releases chemicals which will put out a chimney fire safely. If we were to use water on the chimney, we could very easily crack many of the bricks, as they WERE very hot, and are cooled off quickly. |
#8 |
Member#: 2692
SCIC
hey 8,
any paint problems so far? |
#9 |
Member#: 972
interesting... but if this is indeed for fireprotection.. what would prevent the mat from just melting to the top of the hood if it were a hot enough fire *shrug*
#10 |
Member#: 3125
Vehicle:2001 Mustang Bullitt Black |
The '97 Audi A4 1.8T's didn't have the sound deadening material. All I can suppose was either it was not included to let the heat radiate and allow the engine to run cooler, or it was a cost reducing matter... which is my theory.
The V6 engined and '98+ cars (including all the turbo Passats) have the material. |
#11 |
Member#: 3803
Vehicle:07 Mustang GT 285 is a wide tire! |
Be carefull with the fuzz under the hood, it is commonly fiberglass based. be sure to wash your hands if you screw around with it alot. I know one of the main reasons for it is sound absorption, as I tested several working for an automotive supplier. Cars have to pass a Government pass-by sound test, under full throttle (don't remember which gear). If they are close to the req, but not meeting it, they will use tricks like that material to absorb sound to lower that pass-by level. they will also put it in if they feel too much noise is getting inside the car and will annoy the consumer.
If you're wondering how it works, the mechanics take a while to explain, but for example, compare a raquet ball court (very loud, lot of echo, flat hard walls) to a library (quiet, no echo, lots of soft materials like cloth and leather bound books, carpet, usually those textured ceiling tile). Cloth type materials absorb sound fairly well. |
#12 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:2001 2.5 RS/70 Van 02 WRX Rally Stud |
i'd leave it where it is if at all possible.
it's there for a reason... j. |
#13 |
Moderator Member#: 922
Vehicle:04 FXT Red |
Heh, had a few dings taken out of my hood ages ago and broke all the clips. I haven't put it back in yet. Guess that is why I'm planning on a fire extinguisher. *shrug*
| Thread Tools | |
| Display Modes | |
| SCREECHING, swapped UP, now under boost - banshee under hood | mgithens | Factory 2.0L Turbo Powertrain | 26 | 10-02-2006 12:55 AM |
| under hood chattering under part-throttle boost | beauhawk | Engine Management & Tuning | 4 | 09-23-2004 09:06 PM |
| weird noise under the hood | rukkie | Factory 2.0L Turbo Powertrain | 2 | 08-14-2004 01:32 AM |
| Weird noise under hood | QwikRex | Factory 2.0L Turbo Powertrain | 8 | 01-23-2004 05:04 PM |
| Subaru WRC pics from LA Auto Show (some under hood and under car detail) | JamesC | Motorsports | 36 | 01-29-2002 05:10 AM |
