Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 02-18-2001, 05:53 PM   #1
Sin
Member#: 2403
1998 Impreza 2.5RS
Rally Blue
Post Engine swap or turbo kit
what do you guys think i should do?
Engine swap or get a turbo kit
i saw on ebay few weeks ago of a 97 StI impreza engine with 280 hp (not sure) and i think the bids went up to about 3K which costs about as much as the turbo kit
Sin is offline
Old 02-18-2001, 09:16 PM   #2
markus
Member#: 438
2004 STi
White on Gold
Post
This topic has been discussed to death on this board numerous times and you will find a wealth of info by simply clicking on the search button by the "Post Reply" button near the top of the page.
However, that being said, if I were to summarize a lot of info in two or three sentences, it would be as follows:
Swapping a turbo EJ20(WRX, STi) or EJ22(Legacy turbo) engine into an RS is as expensive or more expensive than a turbo for the RS. The numerous EJ25 turbo owners on this board will tell you that as long as an EJ25 has proper fuel management, it good for easily 300+ hp. The weak link is the tranny, even on the ones that come with the EJ20/EJ22 motors.
Feel free to PM me if you have any other questions, but this question ultimatley belongs in the Newbie forum.
Hope this helps.
Cheers,
MB
[This message has been edited by markus (edited February 18, 2001).]
markus is offline
Old 02-18-2001, 10:10 PM   #3
andyC
Member#: 1607
2002 Silver
double you are ecks wagon
Post
but what about from the position that you are starting with a 1.8 instead of a 2.5?
andyC is offline
Old 02-18-2001, 10:19 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
If I were starting with a 1.8l Id build up a 2.2l block and put an aftermarket turbo on it. 1.8l wont get you enough power, and 2.2l blocks are cheap. Trouble with the SOJ engines is that they are tuned to run on higher octane than we have readily available. Either way you're looking at a fairly expensive build.
Midwayman is offline
HTML code is On
Engine swap or turbo kit? dracatero Texas Impreza Club Forum -- TXIC 11 10-09-2006 12:48 PM
STI engine swap or turbo upgrade kit?? Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-30-2005 05:55 AM
STI engine swap or turbo kit? Mantis69 Subaru Conversions 6 09-28-2003 12:30 PM
sti swap or turbo kit? decepticon Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-14-2002 05:43 PM
Jap-Spec Turbo Engine? or turbo kit? pumapunt General Community 1 03-12-2002 05:47 PM
