Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 09-04-2003, 08:52 PM   #1
stiwrx
Member#: 7253
Unhappy idle problems w/AC on
Does anyone else have idle problems when the AC is on? Usually on a hot day the car will almost stall, cause the idle will fluctuate when i'm waiting at the light.
stiwrx is offline   Reply With Quote
Old 09-05-2003, 12:39 AM   #2
imposter
Member#: 10642
95 Impreza EJ22T
Check to see that the belt tension isnt too tight.
-Jim
imposter is offline   Reply With Quote
Old 09-06-2003, 12:35 AM   #3
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I would say this is normal. It's the compressor kicking on and then off again. If it's pretty hot out and it's kicking on and off quickly then it may need to be recharged with freon.
dj_noose is offline   Reply With Quote
Old 09-06-2003, 03:56 AM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
A little helpful advice......you may want to fill in your profile info. It helps to know what model your talking about when folks try to respond to your questions.
As far as your question, I would say it's not normal. Your car should not be that close to stalling with the a/c on. However, as DJ points out, it's normal for the rpm's to fluctuate as the compressor cycles. Does it feel really rough? Has it ever actually stalled? Perhaps your mis-interpreting the slight drop in rpm's as a near stall?
- Kean
Kean is offline   Reply With Quote
Old 09-06-2003, 05:14 PM   #5
stiwrx
Member#: 7253
Thanks for all the suggestions. I loosened the belts, but I still have the idle problem. Haven't checked the second suggestion about the Freon yet. Now I have a check engine light on, hope this relates to the idle problem. Then I'll know what the problem is for sure.
Old 09-19-2003, 04:19 AM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
ummm like 3 weeks ago I took my 95 Impreza 1.8 out for a drive.. I was waiting at the light with the Ac on and I felt the car idle rougher then the normal Idle I see that the car was idleing under 900 Rpms.. I don't know what it was but it never stalled that day.. But it's start Rpms are crazy... You start the car it will go over 1,00 then drop to 900 then go back over 1,000.
Also My AC in my impreza cuts on and off every 24 Seconds is that Normal? In the Forester it's every 7 Seconds.
SubaruImpreza_power is offline   Reply With Quote
Old 05-29-2009, 02:29 AM   #7
nyckanny
Member#: 212518
- Kean
Hi, i know this was ages ago. Did you ever get this problem fixed? what happened with it?
kenwei@gmail.com
nyckanny is offline   Reply With Quote
Old 05-29-2009, 12:31 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
clean the MAF
Slight smoke on idle with AC on Nathan Explosion Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 04-14-2010 08:38 PM
Problems with AC and Idle! stierzy34 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-26-2009 02:12 PM
AC on. AC off. AC on. WRX Jim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 48 09-04-2007 10:45 PM
Hiccup @ idle w/ AC on... Kev5n24 Baja Forum 17 07-09-2007 12:13 PM
Surging/pulsing idle with AC on? Slalom RS Normally Aspirated Powertrain 8 09-11-2006 02:57 PM
