Old 02-18-2001, 05:30 PM   #1
Die Civic
Member#: 3301
2001 RS
Question Clutch Ignition Thingamajig
I remember someone posted something about turning that cut off switch thingamajigbobafluxcapacitator thing so that you don't have to dig that clutch into the ground to start your car. I forgot how to do it, and where it's exactly located, and yes I've tried searching, and I got was "ACT Clutch" and stuff about clutches, nothing on how to do that.
Die Civic is offline
Old 02-18-2001, 05:43 PM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Take a look at the clutch pedal. There're two wires running to a switch, & if you clip them & attach them to each other, you should be in business.
RidinLow is offline
Old 02-20-2001, 10:36 AM   #3
Die Civic
Member#: 3301
2001 RS
Post
Nah, I remember him saying something about turning something counter clockwise, and something else.. ? I don't feel kosher about cutting anything that's got to do with the ignition
Old 02-20-2001, 10:40 AM   #4
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Post
I think that ridinlow is correct. Every clutch safety I've seen is a simple contact closure switch, kind of the same lines as how brakelights turn on. Anyone else?
tcs007 is offline
Old 02-20-2001, 11:09 AM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
Post
I think he is looking for adjustment, not removal advice. It is a bad idea to remove the feature, and I think it maybe be illegal it remove a safety feature.
Making so that you did not have to masht he clutch into the firewall would be a better idea.
Jeff
jeffg is offline
Old 02-20-2001, 11:14 AM   #6
Rob K
Member#: 2777
Post
I disabled the clutch on my brother's RS recently. Takes about five minutes. Look at the clutch pedal lever, there are two switches on it, as you push the clutch in the lower button will open right away (this is for the cruise control), but the top button won't open until the clutch is almost to the floor. Just pull the connector off the top switch, and jumper the two terminals using 2 spade connectors joined by a short piece of wire.
Rob K is offline
Old 02-20-2001, 02:36 PM   #7
SubEd
Member#: 717
Question
Crap, I did that mod 2 years ago, and don't exactly remember how! Crawl under there and adjust a bolt to lessen the pressure. Vague enough?
Ed
SubEd is offline
Old 02-20-2001, 05:15 PM   #8
Die Civic
Member#: 3301
2001 RS
Post
lol@subed, but anywho, Bump
HTML code is On
thingamajig?? subyrocks22 Built Motor Discussion 3 04-01-2007 03:56 AM
Cool Visited Countries map Maker Thingamajig WagonMonster Off-Topic 25 11-24-2004 04:57 PM
simultaneous clutch, brake, tranny, throttle, and ignition failure! micah Off-Topic 56 02-03-2004 02:04 PM
Single stage booster, clutch kit, ignition coils, and springs vrg3 Private 'For Sale' Classifieds 12 12-18-2003 11:31 AM
What do you use to remove the stock muffler from the cushion rubber thingamajigs? Bradus New England Impreza Club Forum -- NESIC 4 11-21-2002 09:04 PM
Message Board Statistics All times are GMT -4. The time now is 11:56 PM.
