Closed Thread
Old 10-13-2003, 01:05 AM   #101
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Originally posted by santofontana
I have the same oil drain plug gasket and tranny plug gasket on my car that it came with. Guess what? No leaks. (35k)
Between going out and buying a siphon pump because you overfilled your tranny, and replacing a drain plug gasket because it gets a little oil on it, I think this guy is a little weird.
That's funny though. The guys at Subaru told me they replace the oil plug gasket every time they do an oil change. Is this just some mumbo-jumbo to keep me from going to my "other" mechanic?
04EJ20 is offline
Old 10-13-2003, 01:11 AM   #102
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Replacing drainplug gaskets cant hurt, and they are cheap, so its not a bad idea, but a leaky drain plug gasket is not going to dump all your oil and cause a catasrophic failure.
Id say the advantage of going to the dealership is they will use the oem filter and they will like you more when it comes time to get some warranty work done. Dont expect the bulk oil they use to be any good though.
santofontana is offline
Old 10-13-2003, 01:32 AM   #103
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Tomorrow I'm going to get it changed, and with 10K on my car I'm switching to Mobil 1 Synthetic. Subaru should be able to handle that one. They say that's what they use for their synthetic. Then again, I've heard of stories where they say they use it but they don't to save $$$.
04EJ20 is offline
Old 10-13-2003, 02:19 AM   #104
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Originally posted by JDMSubaru
Yes the dealer told you right. Don't listen to that slob. If he wants to be lazy and not change a gasket because he wants to save a $1.35 oil gasket then let him...
If you can't do the easy oil change your self (no offense), I'd go to the dealer just because they have more accountability than say the mom and pop lube shop or Paco at Jiffy Lube who will use recycled oil in your engine and overtighten (or possibly not tighten securely) your oil bolt.
A guy I know in our local car club had his oil changed earlier in the morning several Saturdays ago and the idiot 'lube-tech' at Jiffy Lube did not fasten the oil bolt securely enough that later that same night when he was driving it came undone and spilled all of it out on the road. 4 or 5 of us pulled to the side because his car overheated and we soon concluded from the thick, long oil streak what happened. When we opened his hood his header was orange-red from the heat. We couldn't believe the sight. It looked like one of those Katanas a Japanese sword maker would heat up to mend sharp with a hammer...
Sometimes it pays to do things yourself. Would you purposely do a bad job or ruin your own vehicle? Of course not, so go to Sears, buy a couple mechanics sets and the service manual from Subaru and then you will have everything done well and perfectly. Personally I even use a torque wrench set to 33 lbs. and use 11 lbs. on the filter wrench. That way I torque every part related to the oil change precisely.
DAMN! No I know a guy that works on German cars (I used to have a Jetta) and I let him do work on my Scooby. NEVER Jiffy Lube!!!
04EJ20 is offline
Old 10-13-2003, 05:41 PM   #105
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
The gasket will deteriorate quicker when it gets saturated in oil too.
hmm. my gasket was dead soft annealed copper. what was yours made out of?
ken
ride5000 is offline
Old 10-13-2003, 05:46 PM   #106
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
ken
It is some sort of metal, but it is a "crush" washer that is only to be used one time. It has a ring on it that compresses the 1st time you use it. If you try to use it again most often you have to use unnecessary pressure to get it to work. This is where the problem lies...
04EJ20 is offline
Old 10-13-2003, 07:13 PM   #107
0260B4U
Member#: 33249
2003 WRX
white
Mine didnt haave a crush washer had a bronze looking one , nice and hard no leaks.
My dealer uses Motul everything
0260B4U is offline
Old 10-13-2003, 08:03 PM   #108
WRXIN
Member#: 15405
2004 STI
Silver/Gold - Team Blew
Yep, no crush washer here either. Just a big hefty washer on the drain plug (both tranny and engine oil). I know what a crush washer is and I definitely don't have one. I've changed my engine oil six times myself and not a single leak.
I'm not disagreeing with anyone, just stating my situation.
WRXIN is offline
Old 10-13-2003, 08:36 PM   #109
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
I just bought one today because I've got MT-90 coming in 2 days. It's a crush washer. You wouldn't be able to tell after it's been used...
04EJ20 is offline
Old 10-13-2003, 08:44 PM   #110
WRXIN
Member#: 15405
2004 STI
Not sure what you mean but its pretty easy to identify a used crush washer, its crushed...
And mine does not have crush washers. I was very careful about that with the first oil change and there was no crush washer. A used crush washer doesnt disappear, its just a crushed crush washer.
WRXIN is offline
Old 10-13-2003, 09:14 PM   #111
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Alright man. I give up!
04EJ20 is offline
Old 10-13-2003, 10:30 PM   #112
makofoto
Member#: 25243
2006 Legacy Outback
04EJ20 ... keep us posted about how you like the MT-90.
I'm going to suck out a quart of my oem MT oil and replace it with a quart of MT-90. Straight MT-90 was great ... just chickened out after a few K's ... now trying a mixture ...
makofoto is offline
Old 10-13-2003, 11:11 PM   #113
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Alright, I will. It's either that or Shockproof will be next...
04EJ20 is offline
Old 10-14-2003, 02:56 AM   #114
WRXIN
Member#: 15405
2004 STI
Not a contest!
I'm probably going to try some of that redline 75w90ns and i'll post my results as well.
-Mark
WRXIN is offline
Old 10-14-2003, 12:44 PM   #115
makofoto
Member#: 25243
2006 Legacy Outback
Just remember that if you are trying to get easier downshifts, faster upshifts ... you need more friction to get those synchros working ... super slick synthetics won't help in that regard ...
makofoto is offline
Old 10-15-2003, 12:13 AM   #116
makofoto
Member#: 25243
2006 Legacy Outback
well .... ?
I'm going to replace 1.5 qts. of my oem MT oil with MT-90 ... and see if it helps with easier down shifts and faster up shifts without crunching. Of course having a short shifter makes it easier to beat the syncros ...
Hoping this mix will be a decent safe combination ...
makofoto is offline
Old 10-15-2003, 12:21 AM   #117
makofoto
Member#: 25243
2006 Legacy Outback
makofoto is offline
Old 10-15-2003, 05:02 AM   #118
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
well .... ?
Good luck! It sounds like it should be...
04EJ20 is offline
Old 10-15-2003, 05:12 AM   #119
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Not a contest!
-Mark
Hold off on that man. My tranny w/ 75W90NS is horrible. Shifting in to 4th grinds everytime, but shifting in to reverse is better (big deal!). I let you know jow I make out w/ the MT-90. From what it sounds like, these guys like it too...
04EJ20 is offline
Old 10-15-2003, 09:31 AM   #120
BIGSKYWRX
Member#: 7958
09 GH B+
Reading through the redline blurb, it appears that the MT would be a good choice. If it doesn't work- shockproof will.
Big Sky
BIGSKYWRX is offline
Old 10-15-2003, 10:17 AM   #121
fliz
Member#: 30342
Big Sky
I read the part about "This product is not designed for use in a rear-wheel drive differential which requires a GL-5 lubricant."
I would extend that to mean that it is not designed for our front differential, which also requires a GL-5 lubricant (and is designed much like a RWD differential).
I personally changed to Shockproof superlight two weeks ago. No problems before the change, no problems now. The only possible change is that I can drive around in 4th at 32 mph, where before the lowest it wouldn't bog down was 35 mph. But that could be my imagination...
fliz is offline
Old 10-15-2003, 11:19 AM   #122
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
The more I read about GL4, GL5 lubricants the more confused I get. There so many mixed messages about which to use, which corrode, ect.
04EJ20 is offline
Old 10-15-2003, 11:23 AM   #123
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
like me, i suggest you keep wondering where all the people with worn out bearings and gears are.
i see stories of worn out syncros all the time.
ken
ride5000 is offline
Old 10-15-2003, 12:43 PM   #124
makofoto
Member#: 25243
2006 Legacy Outback
But whats the point of having a WRX if you have to pause while shifting up to 2nd ...
Maybe by using a lube (MT-90) that allows the synchros to work easier ... they will last longer ... ?
Obvioulsy Cobb Tunning wouldn't mind selling you are new gearbox ... although most of us would get our replacement gearbox from a dealer ... but they do sort of stick their neck out "recommending" MT-90 ....
makofoto is offline
Old 10-15-2003, 05:21 PM   #125
WRXIN
Member#: 15405
2004 STI
Ok, I'll hold off. I now don't know what to do...
I can only say this with confidence, the Mobil 1 Syn results in more grinding when putting the car in 1st. Many people have said that its actually too "slippery" and doesnt have enough friction.
I went to Mobil 1 to try and fix the problem I had with blocking 1st gear. That has reduced a little, but now I have the grinding instead.
Who knows.
Let us know how the MT90 works out.
WRXIN is offline
Closed Thread
V-Spec info revealed rmbrady Non-Subaru News & Rumors 0 07-28-2008 10:56 AM
Gear [back]lashing? gear whine.... info please psyber_0ptix Transmission (AT/MT) & Driveline 4 10-07-2005 10:32 AM
My gear oil odyssey. (non tech info inside) chrisfranklin Transmission (AT/MT) & Driveline 7 05-27-2005 05:05 AM
I need info on changing gear oil (tranny) shogunate83 Service & Maintenance 33 10-21-2002 10:17 AM
