Old 09-05-2003, 01:49 AM   #1
motorswapsleeper
Member#: 38946
199? 6 diff ones
bag o' skittles
Default spark plug wires? need help!
Hey,
I've got a wrx motor and I am running the stock electrical system, the only problem is the spark plug wires won't reach far enough.
My question is...will any spark plug wires work? I don't think on a 1997 legacy I have anything special. I have got a coil pack on top of the motor and normal LOOKING wires on it now.
Maybe I could find some that are long enough that I might have to only cut the plug to fit?
I dunno, I am pretty open for ideas at the moment...
motorswapsleeper is offline   Reply With Quote
Old 09-05-2003, 10:59 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
soo you need wires for a ej20k
shot in the dark, 98 RS (dohc external coil) wires might fit .. you might have to get two sets and use the long wires
Old 09-06-2003, 12:19 PM   #3
Austin
Member#: 7089
2016 STi
What ECU are you using?
If you're using a WRX ecu, then you'll need coilpacks - one per plug.
Austin is offline   Reply With Quote
Old 09-06-2003, 07:58 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
depends on which wrx motor..
Spark plug problems...need help please!! autocannon05 Built Motor Discussion 9 09-13-2008 12:03 AM
Spark plug change, need help!!! ftnjun2x Newbies & FAQs 13 05-13-2006 01:20 PM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
All model Subaru Spark Plug Wires needed Don Nimi Vancouver Impreza Club Forum -- VIC 5 01-12-2002 02:32 AM
I need yellow spark plug wires! Any suggestions? Alpine Sube Interior & Exterior Modification 4 06-11-2001 04:33 PM
