Old 09-05-2003, 03:14 PM   #1
bjsid
Member#: 11707
1998 Legacy GT Wagon
The Silver Pancake 5MT
Default valve cover gaskets... whos done it?
Just wondering if anybody out there has replaced their valve cover gaskets. If so any advice would be appreciated.
I have a DOHC 98 legacy GT wagon
Thanks,
bryan
bjsid is offline   Reply With Quote
Old 09-05-2003, 06:03 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
My father and I did the valve cover gaskets on our MY92 Legacy. There are 3 screws on one bank of the engine and 3 on the other, yours may vary due to it being a 2.5L. Taking them off was a little hard on the driver side. We had to tilt the valve cover between the head and the frame, and take took a breather hose to remove the cover.
Look at the gaskets closely and make sure you put them on the right covers. One side of the gasket may be flat while the other side is rounder. I think the flatter side goes on the cover while the rounder side contacts with the cylinder head, but I'm not sure if all valve cover gaskets are made the same way. The gaskets will be shaped a certain way so don't think it's defective. Put a little oil on the gaskets.
What I did was I put some motor oil on the valve cover and rotated the cover around to get the oil to lube the cracks before putting the gasket on. Put the gasket on the cover than screw it back onto the head.
I hope I don't miss anything, if I do, someone feel free to add more.
FuJi
FuJi K is offline   Reply With Quote
Old 09-05-2003, 07:00 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
they are not to bad, a little pain to get them out.
the bottom back bolts on the DOHC are hard to get to as they are very clost to the cross member.
IIRC you will have 6 boltd on each side.
dont forget to replace all the seals on the bolts as well.
Jay
Old 09-05-2003, 08:59 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Aren't the cover bolts only tightened to 4.3 foot pounds?
Old 09-05-2003, 09:22 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Jay
yea! Don't forget about those! We forgot about those and had to take the covers off again. Thanks Jay!
FuJi
Old 09-07-2003, 09:13 PM   #6
bjsid
Member#: 11707
well I did the fix and so far so good. It was not that hard to do, the bolts took me a little while to get on and off but other than that it is just replacing rubber gaskets.
If any body has any questions let me know.
bryan
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 01:13 AM
Anyone? I Need My Valve Cover Gaskets Done... JohnnyWas Tri-State Area Forum 7 07-28-2007 03:44 PM
Who here has replaced the valve cover gaskets on their 96+ DOHC? MaddMax Legacy Forum 16 05-05-2007 01:42 AM
2 things here. cooling fans/ valve cover gaskets solarsvx South East Region Forum 1 01-21-2003 02:27 PM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 08:50 PM
