Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 09-05-2003, 04:18 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Car cutting out at 3000 RPMs
i dont know what it is. i checked the plug wires, they're fine. i was having problems with the ignition wire of the ECU, i had some wires somewhere that kept shorting out the ignition wire. i pulled the guage wires off of it and it doesnt short out anymore. so what could this cut off be? even very light throttle, it all gets cut back at 3000 RPMS, never shuts off though. when it cuts back, it has a real blah sound to it. someone shoot any ideas to me. thanks!
Brent
scoobyimprza is offline   Reply With Quote
Old 09-05-2003, 05:50 PM   #2
RedBrighton96
Member#: 1246
2011 WRX
Sounds like it could be Limp home mode. Check the MAF wires and the MAF to make sure it's still in one piece.
Rob
RedBrighton96 is offline   Reply With Quote
Old 09-05-2003, 06:25 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Is the check engine light lit?
Old 09-06-2003, 09:55 AM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
what had happened was the ignition wire to the SAFC got pulled too, so every signal that was getting sent into the SAFC wasnt going anywhere. so yeah, in was basically the MAF signal. all is well for now. thanks.
Brent
High idle with power power cutting out at high rpms subie9022 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-14-2009 12:21 PM
Power assist cuts out at low RPMs ('05 STi) case Brakes, Steering & Suspension 2 02-22-2008 10:49 AM
Cut out at 5k RPM? Its-A-Manic Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-31-2006 09:47 AM
Car cuts off at 4k RPM! sovietjet Newbies & FAQs 8 05-26-2006 03:37 AM
Funny sound at 3000 rpm vulcan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2002 09:20 AM
