Old 09-05-2003, 05:24 PM   #1
SubaruPreza
Member#: 21579
2000 Forester
Default Do i need new driveshafts for my EJ25 swap???
I am doing the a 2000 ej25 swap into my 941.8L. I have the tranny from the 2000 RS and i am getting 99RS rear diff. the guy who is selling me the rear diff asked if need driveshafts, and i didnt know, can i use my stock driveshafts an would my shafts fit into the 99rs diff and the 00rs tranny or will i need to get the 99RS driveshafts. or would it be a good idea to get the driveshafts anyways. and will those 99rs shafts fit into the 2000 RS tranny.
thanks
SubaruPreza is offline   Reply With Quote
Old 09-05-2003, 10:54 PM   #2
EddyRS
Member#: 1257
2000 GC8 WRX
93 RS-W Wagon (White) RIP
Hello,
I just completed my RS engine/driveline swap into my 93L wagon. You will need to get the Axles for the RS. The ones on the 1.8 are shaped a little different and will not work on the Rear Diff. Plus they are much stronger and bigger then the 1.8's. The propeller shaft can be used from the 1.8....but I would go with an newer unit from a 2.2L (Which I did) It is also more stongly built then the 1.8 unit.
Make sure that the diff you are getting is from a manual 99, and not an auto. the manual comes with a 4.111 ratio, where as the auto comes with a 4.444. You will need the 4.111. Also the 99 is a NON LSD....only 00-01 RS's came with Limitted Slip Rear Diffs. 02-04 RS's have open rear diffs, as do the 98-99 models.
Cheers
EddyL.
EddyRS is offline   Reply With Quote
Old 09-07-2003, 01:32 AM   #3
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
SubaruPreza, pm'd you.
garface is offline   Reply With Quote
Old 09-13-2003, 03:34 PM   #4
SubaruPreza
Member#: 21579
2000 Forester
Default more questions
will a 2001RS driveshaft fit into the 99RS rear diff and into the 00RS tranny. also sill i need or should I get all four axles for the swap? Will any 98-01 front RS axles fit into a 00 RS tranny?
thanks
Old 09-14-2003, 01:12 PM   #5
EddyRS
Member#: 1257
2000 GC8 WRX
To answer your questions......YES.
98-01 axles work with all combination 98-00 trannies and diffs. On my wagon I have 98 axles (Front and rear) on a 00 RS 5-spd tranny and 99 diff (I have also a 00 LSD diff and it mates up fine too to that......doing some testing with both diffs).
Note: all items are from RS cars.
Cheers
EddyL.
do i need new pistons on my 06 wrx??? jonsdc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-21-2007 09:11 PM
need new plugs for 2.5l swap w/ wrx heads? gimmewar Subaru Conversions 8 05-01-2006 03:26 PM
Do I need Kartboy hangers for my new exhaust? Padge Newbies & FAQs 4 01-10-2006 04:14 PM
Do I need new gaskets for header install? Silverandscared Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-19-2004 11:52 PM
Do I need new gaskets for my Borla headers? mastervic27 Normally Aspirated Powertrain 2 12-01-2000 10:45 PM
