Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 09-05-2003, 11:40 PM   #1
boxerT
Member#: 16311
2004 STi
WR Blue
Default STi Oil Filter, which one to use?
What is the difference between 15208AA060 and 15208AA080?
I think most dealers are using the "060" on the STI and that was what they have sold me. Am I safe using it in place of the "080"?
boxerT is offline
Old 09-06-2003, 12:00 AM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
NO!
Both will fit BUT-
the august 2003 TechTIPS from Subaru says;
"Be advised that the correct oil filter to use on 2003MY/2004MY turbo model vehicles is P/N 15208AA080.
This includes the 2004 WRX STi.
Naturally aspirated vehicles should use P/N 15208AA/05208AC060.
Using the wrong oil filter on a turbo model may put the filter too close to the turbo down pipe and possibly cause an unnecessary heating of the oil filter."
Some people have reported that their STi's shipped with an 060, however.
Use with caution.
z
z is offline
Old 09-06-2003, 08:17 AM   #3
CloNeGTS
Member#: 23341
04 Rex STi
WRB/Gold
Oh God....not again!
080.....
CloNeGTS is offline
Old 09-06-2003, 12:16 PM   #4
MKIVSupra
Member#: 4441
2004 WRX STi
WRB and Gold
FYI... I used 2, 060 filters(all the dealers around here had) up to 6k miles and had no problems.
Now I am using Amsoil oil and filter.
MKIVSupra is offline
Old 09-06-2003, 06:00 PM   #5
z
Member#: 41762
04 STi
I'm sure you're engines not going to seize up on you, but your oil temp is probably hotter than normal, albeit maybe not much. (I don't know, I haven't done any tests)
But hotter oil means less viscosity, so maybe long term = more engine wear?
Like I said, this if from the August '03 subaru TechBulletin, and they're saying "ALL TURBO MODELS" (including wrx and STi, Forrester).
They must have felt the need to instruct all of their technicians that they should be using 080 filters and not 060 filters on all turbo models.
Who knows? Maybe they've "discovered" something after warrantying a few motors.
z is offline
Old 09-07-2003, 01:58 PM   #6
MKIVSupra
Member#: 4441
2004 WRX STi
WRB and Gold
If it was so important why did it take so long for the info to come out? I already had 1 oil change done where the dealer told me the 060 was the one to use. Then when it was time for my second one this big debate was just starting. The dealer still told me the 060 was the one. Should I have waited 5k miles before I had my first oil change? I sent SOA an email about what correct filter to use, it took them a couple weeks to come up with a definite answer. Then I asked if I would have a problem since I have been using the 060 and they said no.
Old 09-07-2003, 03:10 PM   #7
z
Member#: 41762
04 STi
I don't know bro.
But I personally am going to use an 080
z
PM me with an email address and I'll send you the info
z is offline
Poll: Which one to use? sc00ter Off-Topic 31 10-18-2007 11:37 AM
Short Block which one to use? dsm02c Built Motor Discussion 10 01-17-2007 03:53 PM
Which one to use? bendavi17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-27-2006 05:13 PM
OMG I have 2 clutches for autox, which one to use? crystalhelix Motorsports 9 03-09-2006 08:20 PM
Redline Fluid Ratio, which one to use? psaeko Transmission (AT/MT) & Driveline 0 02-17-2003 03:01 PM
