Old 09-05-2003, 11:52 PM   #1
panicme
Member#: 39676
2002 Impreza WRX
Default My first 1/4 mile run
Hi, all! I just bought my '02 Rex about 2 months ago and want to get any suggestions you all might have about my first run. This is my first post AND my first time ever on the track so be kind to the super noob! --Mike
temp - 67
baro. - 30.63
r/t 1.055
60' 2.143
330 6.29
1/8 9.68
mph 72.28
100 12.613
1/4 15.105
mph 90.05
PS I am bone stock down to the air filter. I did my launch holding revs at about 3750 rpms.
panicme is offline   Reply With Quote
Old 09-06-2003, 12:02 AM   #2
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
That is pretty slow for your first time out. What is the elevation you are at? My first time out, after owning the car for aprox. 2 months, in a 2001 2.5 RS with just an intake, I ran a 15.005, with one other 15.0 and three 15.1s. Rev a little higher on your launches. You should have at least been in the 14s on your first night.
Ruff is offline   Reply With Quote
Old 09-06-2003, 12:21 AM   #3
panicme
Member#: 39676
2002 Impreza WRX
I'm in the mountains of NJ. so not that high. I'm guessing 1500 ft. The 04 2.5 RS I raced that happened to also have an intake ran a 16.07 so maybe this track is slow. I didn't rev higher on launch b/c I dont want to shock my trans if I can help it. Thanks for your reply, tho I'm looking for any feedback I can get!!
--Mike
Old 09-06-2003, 08:51 AM   #4
tribegolfer
Member#: 26850
2002 WRX V7 STi swap
You really need to launch at 4,000 or higher. I bog even at 4k. If you slip the clutch quickly, even with a high RPM launch, the transmission will not be harmed. Get your 60' down to ~1.9, and you'll be in the mid 14's. Good luck.
Adam
tribegolfer is offline   Reply With Quote
Old 09-07-2003, 01:48 PM   #5
InfamousDX
Member#: 25413
What track did you take it to.. Island, E-town, atco?
Old 09-07-2003, 01:51 PM   #6
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Yah, slip the clutch at about 5000 rpm and you will see a big improvement in your times. IIRC, other stock WRX owners are getting 1.8-1.9 60 ft times.
JewPac42 is offline   Reply With Quote
Old 09-07-2003, 02:55 PM   #7
panicme
Member#: 39676
2002 Impreza WRX
I ran at Island Raceway, which I now know is 500 ft. elevation. I will try the 5000 rpm slip, and report back!
Also, I was shifting at about 6K 6500 rpms this past run. I hear that I should take it into the red my next time out. Does that sound right?
Thanks again, all!
--Mike
Old 09-07-2003, 09:33 PM   #8
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
60 foot is WAY too high. get it down to 1.8x that is .3 seconds right there, nevermind that the gain is compounded by the end of the 1320.
you're launching too low, and you can't just hold the engine at one rpm. try this...
keep blipping the throttle and keeping the revs between 5 and 6k. this will "preload" the turbo. on your go, slip the clutch and floor it. get this down and you can run 1.8x 60 fts consistently.
the really good drivers with modified cars get lower but thats obvious. oh and run it to redline...
my best stock was 14.3
practice before you go to the track again. its not hard, just have to get used to it.
ZoomnWRX is offline   Reply With Quote
Old 09-08-2003, 12:38 PM   #9
WRallyBlue02
Member#: 20157
0503 WRX STI & 03Wag
Asp White, Plat Silv Met
I had my first race at the track this weekend also:
I ran a 13.966 in a CObb Acces ECU stg 2 with stock Can and Gruppe-s uppipe, Helix DP, and samco IC hoses.
My trap speed was 97.xx and I smacked the rev limiter in 3rd 80ft - 100ft before the finish. Do you think I can get to a 13.6? My 60ft was bad- 2.005, I was dumping the clutch not sliping it. I had a bunch of fun, I found out that it is pretty hard to stage.
Ben
WRallyBlue02 is offline   Reply With Quote
my first 1/4 mile run Vampyr Proven Power Bragging 4 09-28-2005 02:03 AM
first 1/4 mile runs for my wrx, SUCKED! ktrends Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 03-15-2002 08:15 PM
My first 1/4 mile White Knight Legacy Forum 7 02-26-2002 08:18 PM
My first 1/4 mile with the WRX - 13.7s Sproing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-23-2001 03:09 PM
