Old 09-06-2003, 12:14 AM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default What is this part in my fuel system. Can I remove this
I am taking all of my stock stuff out and running -8 fuel line from the fuel pump to a russell -8 fuel filter to my fuel rails. I removed the -4 fuel lines from the perrin fuel rails and put in -6 feed lines and -4 return lines. The return lines will goto my aeromotive fuel pressure regulater. What is this part that is on my factory fuel system. Do i need to place this back inline when i put my upgraded stuff on.
STEALTH-WRX is offline   Reply With Quote
Old 09-06-2003, 01:55 AM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
fuel damper on return line
u don't need it
not sure wha's in it though(how it work)
vile is offline   Reply With Quote
Old 09-06-2003, 04:20 AM   #3
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
OMG@!! YOU CAN'T REMOVE TEH DAMPENER, YOUR WHEELS BEARINGS WILL GO BAD!!!1
I am mattjk is offline   Reply With Quote
Old 09-06-2003, 05:08 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Supposedly it smoothes out fuel pressure while the injectors are firing and whatnot. Scrap it.
Old 09-06-2003, 11:35 AM   #5
Austin
Member#: 7089
2016 STi
Originally posted by 8Complex
Scrap it.
Jup.
Austin is offline   Reply With Quote
Old 09-06-2003, 12:07 PM   #6
STEALTH-WRX
Member#: 7822
Thanks guys. Will do.
what is this part called? what is it's part number? OUScooby Private 'Wanted' Classifieds 8 04-21-2010 04:08 PM
What is this part of my brake system and how do I move it? akeric Brakes, Steering & Suspension 2 07-10-2009 07:17 PM
what is this in my oil catch can! simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-20-2007 12:15 PM
Is this in my head or can this mod gain noticeable power? jroberts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-31-2004 01:39 PM
What is this in my fuel return line, and why is it there...argg munkis Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-19-2004 07:21 PM
