Old 09-06-2003, 03:50 PM   #1
J.Stokes
Member#: 42967
2003 WRX Sedan
Exclamation Engine Runs too Hot at Idle
Should my engine/radiator fans run all the time? If not when should the turn on? I was waiting at a train crossing today at idle for about ten minutes and my cars temp kept rising and rising way too high. when I started to drive it went down obviously because air was getting to the radiator. Further investigation I found that the fans are not running. I have checked the fuses and they are fine. when I turn the cars ignition to the on position (not starting it) the fan clicks on and then clicks off. Please Advise
I just did another test. I started the car no fan, I turned on the A/C Fan went on and then turned off in about 1 minute. saw the the A/C pully switch to off in the engine no cool air inside the car (which I have noticed since I've had the car.
J.Stokes is offline   Reply With Quote
Old 09-06-2003, 07:44 PM   #2
Wheeldog
Member#: 19848
2002 WRX Wagon
Lightbulb
I'm guessing that there has to be a previous thread that describes the way the WRX fans work, so your quickest path would probably be to do a search. Or, you could go to the online manuals (Subaru Technical Information service) and download the appropriate manual / page. I have a 2002 WRX and my copy of Volume 8 (Mechanism and function) has the information on page CO-12.
For the 2002 WRX . . . The ECU uses signals from the engine coolant temperature sensor, vehicle speed sensor, and A/C switch. It then decides, based on a combination of the inputs, whether or not to run the main fan and/or sub-fan, and what fan speeds should be used. I can't guarantee the information would be accurate, but you can PM me if you have some specific questions and I'll tell you what the book says. I can tell you this (for the 2002 anyway): If you are under 12 mph (including a dead stop) and you have your A/C off, both fans are supposed to be off unless your coolant temperature is above 96 C. At 96 C and above, both fans should run at low speed.
Wheeldog is offline   Reply With Quote
Old 09-07-2003, 03:12 AM   #3
Austin
Member#: 7089
2016 STi
Austin is offline   Reply With Quote
Running high rpm's at idle T4L_09WRX Texas Impreza Club Forum -- TXIC 4 12-22-2009 03:23 PM
06 Sti Getting Hot at Idle??? FLYBYSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-13-2008 01:27 PM
Things got too hot at Cover Girls metoo Texas Impreza Club Forum -- TXIC 9 01-18-2007 12:40 AM
2.5L Running Really Rough at Idle ?????? w chapman Normally Aspirated Powertrain 13 09-18-2005 03:59 PM
Is engine compartment too hot? HAL1 Newbies & FAQs 1 09-06-2004 11:02 PM
