Old 06-28-2003, 11:54 AM   #1
highspeed11
Member#: 30937
2005 Legacy GT
GRP
Default Check engine light?
It came on last night seems to run fine other than the exhaust rattle. I changed the oil 2-3 days ago. I don't think I screwed it up. I was wondering if a bad fuel filter or air filter would make the light come on. I want to replace both at least the air filter.
Anyone know which K&N filter to buy? Anybody have other reasons this may have came on?
highspeed11 is offline   Reply With Quote
Old 06-28-2003, 09:20 PM   #2
highspeed11
Member#: 30937
2005 Legacy GT
GRP
Okay now I have found a problem. It is draining fuel like crazy. I have used like 3/8 tank in about 50 miles more so in the past 15 or so when the check engine lighht came on. I guess I'll be taking it to the shop.
Old 06-29-2003, 04:27 PM   #3
highspeed11
Member#: 30937
2005 Legacy GT
GRP
I called the shop yesterday only to be informed that they won't be open till' monday so I searched and searched on here and didn't find any other thread with this same problem. I decided to reset my ecu and when I turned it back on the CEL was off and the fuel guage went up from a little below half to between half and 3/4.
I drove it last night for about 15 miles didn't notice any movement of the guage so I hope this worked. Any comments would be much appreciated.
Old 09-06-2003, 09:56 PM   #4
jaciuro
Member#: 42992
2002 WRX - Sold.
2005 Suzuki GSX-R 1000
Default K&N FILTER
I know about the filter you want. Go to the local Autozone and ask them for # 33-2232 K&N filter. At 8.25% tax I paid $45.45 for it. A seat-of-the-pants gauge says the filter was an improvement over the stock panel filter, not to mention after the resonator box removal, you can hear the turbo spool-up and blow-off better vs. stock after resonator removal.
I can't tell you anything about that check engine light. I need to clear one up myself. I disconnected the factory blow-off valve from the hose rerouting it to the intake hose. The sound was great, but the idle was rough and it turned on the light. Now I need to get that taken care of.
jaciuro is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
Message Board Statistics All times are GMT -4. The time now is 10:48 PM.
