Old 04-07-2003, 06:06 PM   #1
rexxer
Member Sales Rating: (2)
Member#: 27624
2014 WRX
Default Perrin Crank Pulley
I figured there should be a review of this piece individually (not installed with other parts).
I installed this on my 2002 WRX and this is my first and only (so far) performance mod.
The installation only took about 30 minutes, but the trips to the hardware store took a couple hours. Make sure you have EVERYTHING you need before you start (10, 12, 14mm wrenches, 22mm half inch drive socket, 18" breaker bar, torque wrench, WD-40, couple drops of motor oil).
I followed Vishnu's pulley instructions. They are great! Everything was easy to do until it go to the pulley itself. It didn't want to come out. We tried 3 different pullers and none of them fit inbetween the pulley and the fans on the radiator. We ended up having to let some WD-40 soak in and then just get two people to pull and wiggle the pulley for a couple minutes as it slowly came out.
No dyno tests, but the power gain is not noticeable. What is noticeable is the quick throttle response and very smooth driving while not on boost.
Also, the car had no trouble starting of idling at temperatures between -9C and +9C.
rexxer is offline   Reply With Quote
Old 04-07-2003, 11:50 PM   #2
2003forcefed
Member#: 28643
2007 STi
Urban Grey Metallic
Cool..would you say it was worth the money? Thanks for the review.
2003forcefed is offline   Reply With Quote
Old 04-08-2003, 12:17 AM   #3
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
This is on my short list for mods as mod money becomes available. Worth doing DIY install? Would a particular tool have made it much easier?
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 04-08-2003, 12:59 AM   #4
Uncle Scotty
Member Sales Rating: (5)
OK buy Nates beans
westcoastroasting.com
I installed mine about two weeks ago, and noticed the difference immediatly. IMHO a worthwile mod. Better/easier rev-matching, better off-idle transition, overall better driveability.
Just follow the instructions, and if the OEM pulley is stubborn, use WD-40 and a rubber mallet to GENTLY persuade it to come loose. DO NOT drop/loose the woodruff key.
DO NOT cross thread the crank bolt.
Good luck
Old 04-08-2003, 11:17 AM   #5
rexxer
Member#: 27624
2014 WRX
Yes, the WD-40 and rubber mallet with another set of hands is the only way to get the stock pulley to budge sometimes.
Then more I drive with this pulley, the more I like it.
For around US$125 it is worth it. By the time it got to me it was about $260 Canadian... still worth it, but slightly less worth it.
Old 08-17-2003, 11:58 PM   #6
mawgyit
Member#: 33807
03 WRX
Does the car noticably pulls harder during acceleration or 'faster'?
I would think this would be the only reason where less rotational mass would be good
mawgyit is offline   Reply With Quote
Old 08-18-2003, 10:59 AM   #7
rexxer
Member#: 27624
2014 WRX
Short answer... not really. It doesn't pull hard enough to really notice it.
Rev matching is much easier, and your revs drop faster, so you can shift faster... which will make you want to buy a short shifter...
Old 08-18-2003, 11:15 AM   #8
mawgyit
Member#: 33807
03 WRX
Thanks rexxer. IMHO this seems like this is a mod I'd do after I run out of things to add
Old 08-18-2003, 11:17 AM   #9
rexxer
Member#: 27624
2014 WRX
I don't know what you've done so far, but I found the uppipe and engine management to be really good mods.
Old 08-18-2003, 01:17 PM   #10
0260B4U
Member Sales Rating: (1)
Member#: 33249
2003 WRX
white
This is the light weight one correct?
And where did you get it for 120?
0260B4U is offline   Reply With Quote
Old 08-18-2003, 01:22 PM   #11
rexxer
Member#: 27624
2014 WRX
Nino's Auto Accessories. They usually have a bunch of these Perrin Lightweight crank pullies:
Nino's post
Old 08-18-2003, 01:23 PM   #12
mawgyit
Member#: 33807
03 WRX
[rexxer] performance wise Nada. yep those are on exactly on my list. I'm thinking of TurboXS UTec then maybe uppipe. Trying to avoid as much physical eng. mods as possible for warranty
I second Nino's. Got all my mods from him. A great personable guy. Just PM him or call.
Old 08-18-2003, 01:25 PM   #13
rexxer
Member#: 27624
2014 WRX
I ended up buying a used unichip for Vishnu Stage 0 (oldschool -- uppipe, crank pulley, MBC, sparkplugs) after I installed the uppipe and crank pulley. WOW... what a difference! I do throw a CEL once in a while, though.
Old 08-20-2003, 11:29 AM   #14
CirrusWRX
Member Sales Rating: (4)
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Just to chime in, I have the AutoSpeed Performance pulley, and I believe it is nearly identical to the Perrin - perhaps a little bit heavier, if anything. And I confirm what these other guys are saying-- no real noticeable "power" increase, but engine rev's more freely, easier heel/toe, revmatch, and "shifting" IMHO.
CirrusWRX is offline   Reply With Quote
Old 08-28-2003, 11:47 AM   #15
Jejunum
Member#: 15773
2011 Impreza WRX
what did you guys tighten the 22mm bolt that holds the pulley in at?
<110 ft-lb for me
Jejunum is offline   Reply With Quote
Old 08-31-2003, 11:02 AM   #16
badkid
Member#: 42275
2004 WRX Wagon
Platinum Silver
Vishnu Tuning's installation instructions are defininitely more useful than the accompanying Perrin instructions.
Getting the original pulley off the shaft wasn't that difficult for me. It was stuck in, but after 5 minutes of soaking in Liquid Wrench, it slid off with almost no effort! Maybe it's because I only have 2000 miles on my car (no gunk has accumulated).
The most difficult part is getting that @!#$@ alternator belt back on!
I torqued mine to 100ft-lb.
I dunno if I feel any extra horsepower, but at low RPMs, I do imagine feeling a little extra torque when I'm engaging the clutch in 1st gear. Shifting has also gotten "easier".
badkid is offline   Reply With Quote
Old 09-02-2003, 11:00 AM   #17
phasedlife
Member#: 15613
2009 Impreza WRX
Thumbs up
No dyno or anything, but I have this installed as my first real performance MOD(I had only a AEM CAI at the time) and I also have a 4EAT. I noticed a difference in spool up time. That's it. The power difference I'm sure is minimal, but I definately noticed a speed increace. You lose lag, that's the best way to describe it. It's worth the like 130 bucks I paid for it. It's chump change as far as speed boosting is concerned. I had the dealer install it because I did not have a tourque wrench. about 30k miles with it on now, not a single issue/problem/CEL. I now have full exhaust mods and a grounding kit. The grounding kit had a similar "lag-reducing" effect for me, only the grouding kit killed a quick stutter I had, while this is a more smooth effect over the low/mid RPM range.
Adam
phasedlife is offline   Reply With Quote
Old 09-02-2003, 11:16 AM   #18
Jejunum
Member#: 15773
2011 Impreza WRX
Adam
wow your dealer did it for u!!! my dealer wouldnt even put on an oem sway bar for me...
Old 09-02-2003, 07:21 PM   #19
0260B4U
Member#: 33249
2003 WRX
white
Damn dude you could have picked up a torque wrench for half or less than what you paid your dealer to put it in.
Old 09-02-2003, 07:32 PM   #20
Jejunum
Member#: 15773
2011 Impreza WRX
heh - it was a pretty hard install though dont you think? i ended up taking out my fan shroud and disconnecting a radiator hose.
and i had the 4eat issues - had to put a breaker bar in TC
Old 09-03-2003, 10:54 AM   #21
rexxer
Member#: 27624
2014 WRX
The removal of the stock pulley was a PITA, but the rest was easy. Do an uppipe install and you'll know what a hard install is!
Old 09-09-2003, 01:51 PM   #22
phasedlife
Member#: 15613
2009 Impreza WRX
Yes, uppipe... gigantic hemerroidal PITA.
<= Trys to remove and keep track of a hundred nuts and bolts
I looked at doing the pulley by myself. I have a breaker bar and a torque wrench now but at the time I did not. I did not feel confident and that's the bottom line. I knew they would do a good job and tension all the bolts and belts correctly,... etc. It was expensive to get it installed but Pence Subaru did not even blink at the oppertunity to make me happy and profit at the same time. Not to mention they have a reason to void my warranty now on whatever, I'm sure. If I had to do it again, I'd do it myslef and do it right.
Adam
FS : Perrin crank pulley and perrin shifter bushings heat7881 MAIC Private Classifieds 2 10-12-2009 05:53 PM
Perrin crank pulley vs. GFB 2 pcs pulleys gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-21-2008 06:37 PM
FS: Socal: Perrin crank pulley, Perrin Fuel Rail Kit, Injen Cross-Pipe. RSXiMUS Engine/Power/Exhaust 7 04-30-2008 05:54 PM
I will trade my perrin crank pulley for a stock crank pulley NITROS Mid West Subaru Owners Club Forum -- MWSOC 8 07-21-2006 10:51 AM
Perrin Crank Pulley Vs Unorthodox Racing Ultra S lightened underdrive crank pulley west_minist Normally Aspirated Powertrain 3 02-21-2005 11:56 PM
