Old 09-06-2003, 11:29 PM   #1
Imprezd
Member#: 3357
Unhappy Doing a Conversion without the harness lOOK HERE
Ok, so you have bought an Engine and it doesn't have the complete harness.
If you are feeling up to task you can use one of these jammies to get you going.
What you will need to do is cut the leads off at the board and label each strand of wire that you add. The idea of the whole setup is to use alot of the wiring from the car that you are doing the swap in or you can re-wire completely the whole ecu harness section.. which would be my choice. Then you can do whatever you want with the ecu harness.
Imprezd~
P.S. http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:LC:MT:1
WRX ECU pinout will be added if needed.
Imprezd is offline   Reply With Quote
OMG im turning old friends of the whitt look here whitt Southern California Impreza Club Forum -- SCIC 26 01-24-2005 01:22 PM
Looking for a grille without the honeycomb look. djoye General Community 0 05-30-2004 10:04 AM
how to do compression test without the battery? twlai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-31-2003 01:49 PM
Wiring Morettes without the harness? BeavisNuke Interior & Exterior Modification 3 03-28-2003 10:43 PM
How do i hook up the Blitz FATT DC without the harness ? SubyNewbie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-02-2001 09:52 AM
