Old 09-07-2003, 11:45 AM   #1
apollo
Member#: 31007
2005 STi
Default Question about the 11.9 sec Turbo XS WRX
I know they put their Stage 4 TMI on the WRX, but did they also use nitrous to achieve the 11 sec? If you check the "details" page for the car, they show a nitrous set up, so I am thinking they did use nitrous. Anyone know for sure?
apollo is offline   Reply With Quote
Old 09-07-2003, 12:04 PM   #2
onesillyracer2k2
Member#: 19338
05 Legacy GT
GRP
yes i believe they used a 50 shot for the run.
onesillyracer2k2 is offline   Reply With Quote
Old 09-07-2003, 12:32 PM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I think it was Phil who ran the car. They did use Nitrous. They went [email protected] I think Phil said he mis-shifted or something along those lines. There was def. a bit more out of that car.
Need4Boost is offline   Reply With Quote
Old 09-07-2003, 07:34 PM   #4
Szm426
Member#: 11679
yea i remeber reading that they used a nitrous express wet kit, i think its on thier web site....
Sam
Szm426 is offline   Reply With Quote
Old 09-07-2003, 10:48 PM   #5
jinxproof99
Member#: 21497
they used a 50 shot, but the car weights like 3400++. body kit, full interior, etc........
jinxproof99 is offline   Reply With Quote
Old 09-10-2003, 02:40 AM   #6
Big Turkey
Member#: 32118
What type of dyno does TXS have? Does it read higher or lower than a Dynojet?
Is that dyno graph of 376hp dynoed with the nitrous kit?
Big Turkey is offline   Reply With Quote
Old 09-10-2003, 11:04 AM   #7
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Yes, I used a NX 50 shot. I drove the car really well but we ran out of NX at the end of the track so the AFRs became excessively rich. We ran the car again with the same setup and trapped at 117 mph but I didn't drive well and only managed a 12.0.
Power doesn't guarantee a timeslip as I ran a 120 mph trap this past weekend and only managed a 12.6 et. LOL! This was all turbo. That was at low boost and once we had the car running well, we turned up the wick and blew out the center diff.
We have a Dynapack 4000 and it reads really close to a Dyno Jet (+-15whp).
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 09-10-2003, 03:25 PM   #8
Big Turkey
Member#: 32118
Thanks,
Phil
TurboXS
Phil,
120mph all turbo is insane! What turbo are you running now? The reason why I was asking those questions is because I'm headed to the track tomorrow but I wonder what I was going to trap at with the power that I put down, which is 345.6hp, 359.9ft/lbs of torque.
Old 09-10-2003, 06:16 PM   #9
MattSEG
Member#: 4603
1994 Mioterr R pack
Red
Wow...sorry I missed reading about that before. Thats truely remarkable, congrats.
MattSEG is offline   Reply With Quote
Old 09-10-2003, 09:49 PM   #10
Davenow
Member#: 23676
Guys, Phils motor is putting down SERIOUS power. Go ahead ask him what happened on the dyno when he first got the new turbo on and rolled on the throttle in 2nd gear.....
*hint it rymes with stripped teeth off 2nd gear
I think he was saying like 450+ft/lbs at the wheels before it let go
Old 09-10-2003, 10:44 PM   #11
nmyeti
Member#: 4980
I think you are confused. Phil made around 399ft/lbs. Someone recently made about 450ft/lbs on our dyno, but it wasn't him
I'll let you guess who it was
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 09-11-2003, 12:49 AM   #12
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Anna?
Wombat North is offline   Reply With Quote
Old 09-11-2003, 01:58 AM   #13
2MANYCARS
Member#: 24046
2007 STi, EVO, M6
E55, ML63, & Old 02 WRX.
450!? Damn, that's a lot of torque!! Let me guess though, at 5000-6000rpm range? And I am thinking the setup that made such torque is a 2.5L with race gas, right?
2MANYCARS is offline   Reply With Quote
Old 09-11-2003, 03:37 AM   #14
Big Turkey
Member#: 32118
-Nathan
www.turboxs.com
Phil stripped 2nd gear making 399ft/lbs? Holy crap, I was thinking about spraying the car but hell no, I'm only 40ft/lbs away.
Old 09-11-2003, 07:10 AM   #15
Davenow
Member#: 23676
-Nathan
www.turboxs.com
I will crap if you say it was the SRT-4. It had to be. WE all know the SRT-4 is fastAr
Wait, was it?
Old 09-11-2003, 09:16 AM   #16
nmyeti
Member#: 4980
No,
Phil stripped his 2nd gear long before making 399ft/lbs on our dyno, but 399ft/lbs (457whp) does number on the center diff.
On our dyno I think he was making a true 350 ft/lbs (410whp) when he killed 2nd gear from a roll.
At 405ft/lbs (270whp is where the dyno stopped recording at 3500rpms) at the wheels he sent a stock rod though the block.
A VF30 with n2o can produce a whole lot of torque, so be careful about hitting it below 4500 or you may cause yourself lots of trouble. It's better to use it up top where you just don't have that much with a VF30.
By the way, the aforementioned 450ft/lbs car made 497whp
One last note the HP numbers above are the peak numbers for the setups listed, not the Hp they were making at the RPM they produced the torque in question. The exception is the last one where it made peak HP and peak torque just before the rod went though the block.
Old 09-11-2003, 11:06 AM   #17
motoxphil
Member#: 5094
Here's a list of what's currently on my car:
http://www.turboxs.com/ProjectWRX.htm
My stock transmission blew out second gear from a role on pump gas with our Garrett Turbo Kit (not yet available). Actual HP was unknown but but I was running a little more boost at the time
When we raced the car last weekend it was with my new setup at low boost.
Thanks,
Phil
TurboXS
Old 09-11-2003, 11:12 AM   #18
Davenow
Member#: 23676
Thanks,
Phil
TurboXS
I actually like the body graphics on that. That race block kit has me drooling...
Old 09-14-2003, 03:51 AM   #19
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
So.. the $4k for the race engine is for a complete longblock or shortblock? (short I would imagine... if so, how much more for heads?)
DubuRX is offline   Reply With Quote
has anyone seen turboxs 11.9 sec 115 mph odin1 Proven Power Bragging 11 11-13-2002 12:04 PM
Question About The Turbo Xs Race Pipe BLUETURBOWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-09-2002 12:09 AM
Hi, question about the turbo on the wrx... kwakman Newbies & FAQs 8 09-01-2001 11:06 AM
Question about the Legacy 2.2 Turbo bri99RS Technical Forum Archive 11 05-24-2000 11:59 AM
