Old 09-07-2003, 02:30 PM   #1
maharashii
Member#: 41022
Default Wiring harness for stock fog lights in 98 OBS
Hi guys,
just picked up some stock fog lights (used) for my 98 OBS.
Looking inside the bumper, I can't see any connectors to power the lights. I unwrapped the wiring harness that goes to the headlights/turn signals, but I don't see any hidden connectors in there either.
I would think that subaru would use the same harness and just tape up the unused fog connectors for cars w/o the fog light option.
Is this not the case? Do I need to do all my own custom wiring?
maharashii is offline   Reply With Quote
Old 09-07-2003, 09:53 PM   #2
avk
Member#: 17252
'06 WX8
59E
Apparently among 1st gen. Imprezas (as well as 2d gen. Legacies), only the cars with factory installed fog lamps had the necessary wiring. Add-on fog light kits sold by Subaru include an extra harness, actually two harnesses.
avk is offline   Reply With Quote
Old 09-07-2003, 10:27 PM   #3
maharashii
Member#: 41022
what did that harness connect to? Did you have to splice into the existing harness?
Will there be any wiring going back to my fog light switch, or do I need to splice or run wire there too?
Old 09-07-2003, 11:10 PM   #4
avk
Member#: 17252
'06 WX8
59E
The add-on fog lamp kit includes what can be called a power harness, and a control harness for the switch and relays. There actually are some tap-in connectors, but only for low-current circuits. Other connections to the existing wiring use a pass-through pair of plugs in one place, and adding extra pins to a couple of other plugs at the fuse box.
Old 09-08-2003, 12:52 AM   #5
ultrasonic
Member#: 18006
I'll bet your car has most of the wiring already installed. Mine did, but it's MY00, so your mileage may vary. I know my friends MY99 OBS was set up exactly the same as mine.
Look behind your left headlight, just in front of the battery. Do you have a two pole connector hanging out of the wiring harness going to the headlight? If you have that connector, you are likely in good shape.
You will likely have a socket to plug in a relay, and a socket that connects to an OEM switch. All you have to build it a harness that connects your two fog lights to that connector behind the headlight.
If your car has this connector, email me for instructions on getting it all working.
Steve-- [email protected]
ultrasonic is offline   Reply With Quote
Old 09-08-2003, 11:59 PM   #6
maharashii
Member#: 41022
thanks for the head's up. I didn't check behind the headlights.
the car is in the shop this week, but i'll check it out as soon as I get her back
Better wiring harness for stock foglights rougeben83 Electrical & Lighting 7 02-28-2007 03:03 AM
WTB wiring harness for stock (lamco) boost gauge therexisking Private 'Wanted' Classifieds 0 02-05-2005 12:14 PM
Question About CC-B Wiring Harness for EDM STi lights Moviemaker Electrical & Lighting 1 08-08-2003 01:00 AM
Light Bulbs for stock fog lights? mike270 Interior & Exterior Modification 6 01-31-2002 02:28 PM
Wiring harness for stock stereo yebokmj Car Audio, Video & Security 0 11-28-2000 12:17 AM
