Old 09-07-2003, 03:17 PM   #1
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Default Changing oil, different readings!! bahhhhhhh
This might be stupid question, but here it comes. I been chaning oil on my RS for 2 years now, so I have experience. Usually I put 3.7 litres and after adding up bit by bit till FULL mark. But it takes too long, and also I get different readings all the time during that. Today i was doing that and ended up dumping whole 4 litres in there and it was just very little over NOTCH. Now, can I just drained it really good(30 min) and then put 4 litre(whole can)??? Will that work? That would save me so much time and hussle!! I also have Fumoto valve. Thanks guys!!!!!!
Flexy is offline   Reply With Quote
Old 09-07-2003, 08:40 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Just leave a little behind when you pour -- guess where 3.9 or 3.8 liters would be, then you'll be OK. I wouldn't go higher than the notch.
Old 09-07-2003, 09:27 PM   #3
Ken
Member#: 34
2005 WRX STi
World Rally Blue
yeah, I never get a full 4L into it. Did you fill the oil filter first too? My oil readings are crappy so it sucks. bleh.
Ken is offline   Reply With Quote
Old 09-07-2003, 10:18 PM   #4
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Yeah prefilled filter and all.. Just checked right now after driving car for a while. It's like 6mm over the notch. Don't know if it's ok. Next time Must put in 3.8 or 3.9 litres.
Old 09-07-2003, 10:25 PM   #5
Karl
Member#: 13110
I don't think you have to that accurate. As long as you have proper lubrication (not too little and not too much), you should be fine.
Karl is offline   Reply With Quote
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1061 10-22-2015 10:38 PM
Change oil first or start than change oil carpfish Service & Maintenance 5 03-23-2010 04:32 PM
Oil Temp & Pressure Changes w/Different Oil Brand? alpentalic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-02-2009 05:28 PM
change oil filter with every oil change? BlackBeastie Service & Maintenance 1 03-15-2003 07:29 PM
Warning to those who change their own oil. Pls. Read. Snoopy General Forum Archive 37 01-24-2001 10:37 AM
