Old 09-07-2003, 06:11 PM   #1
outferno
Member#: 27469
2004 Forester XT
Default 2 STi Stereo Questions
Dang, I'm so confused. Can someone help me out? I have a STi and I recently did a stereo install but I can't find the antenna input into my deck... Did I have to pull it through from the back and into the front or am I just missing it and not seeing it?
Secondly, can someone confirm that 6.5" speakers will fit the front and that 5.25" speakers will fit the back?
If anybody could shed any light on this, it would be much appreciated. Thanks.
Signed,
Outferno
outferno is offline   Reply With Quote
Old 09-07-2003, 07:53 PM   #2
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
The STi antenna is amplified and there are 2 connections needed to work properly. 1st, you need to connect the big antenna plug(big and black). It might be hidden behind the harness, dig for it. 2nd, you need to connect power to the amplified antenna. Most decks have a power antenna lead coming out of the deck(most are solid blue). That needs to be connected to the STi harness(i believe its white).
If you happen to purchase a wire harness adapter, just follow the directions on the package about connecting the power antenna lead.
Yes, 6.5" woofers will fit with the proper spacer/adapter. For the rear, depending on the speaker, the 5.25" will work. You might have to enlarge the opening slightly.
dsmperformance is offline   Reply With Quote
Old 09-08-2003, 01:59 AM   #3
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
for the rears a 5.25" speaker with a max of 4.7" can fit with zero metal cutting. This is via use of a custom adapter plate.
ALso, for the rears, look for a set of coax that has a flush mounted tweeter to it. I.E. teh tweeter doesn't not extend past the speaker surrond. The space back there is very tight.
IA Performance is offline   Reply With Quote
Old 09-08-2003, 11:00 AM   #4
pushkasmd
Member#: 40791
2004 WRX STi
Thanks, guys. I recently bought an Aiwa double DIN CD/cassette player from Crutchfield. (Excellent support services, by the way, for a little extra money). I have horrible reception on it and I was considering trashing it. Tonight I will look for the white wire and let you know if it helped. I may still have to use the thing as a paperweight - at $250 you gets what you pays for, I guess.
pushkasmd is offline   Reply With Quote
Old 09-08-2003, 03:00 PM   #5
G-force
Member#: 14104
UBER ILikeItLongAndH
ardDeepandSmoothEverSoCoo
if yours came with a supplied wiring harness from crutchfield (which I assume it did) there's no need to locate the white wire...just connect the blue antenna power lead from the radio's harness to the subaru blue wire harness adapter.
G-force is offline   Reply With Quote
Old 09-08-2003, 08:16 PM   #6
pushkasmd
Member#: 40791
2004 WRX STi
Thanks, G-force and all of you. In 20 minutes I had the panel off and the blue wires connected - the radio works like a charm and I am in love again with the car.
Old 09-15-2003, 08:35 AM   #7
outferno
Member#: 27469
2004 Forester XT
Thanks for all the replies folks, but I haven't been on much recently via hours at work. I'm actually thinking of getting Polk DB's for my car now. 6.5 in the front and 5.25 in the rear. Zero cutting right?
I'm scared .
Signed,
Outferno
Old 09-20-2003, 05:21 PM   #8
outferno
Member#: 27469
2004 Forester XT
Well, I got the 6.5" speakers in with no problem, had to do some minor drilling. Now for the 5.25" in the back, I had to do some sheet metal cutting, no harm done. However, I can't find the damn antenna plug. Anybody?
Signed,
Outferno
By the way, I got Infinity
Old 09-20-2003, 06:22 PM   #9
marcus_gonzalez
Member#: 41639
2004 WRX STI
I took my STI to earmark and they were able to put 6.5 component kenwoods in the front and 5.25 in the back with no problem.
marcus_gonzalez is offline   Reply With Quote
07 Impreza wagon 2.5i upgrade stereo questions kaotik78 Car Audio, Video & Security 2 06-10-2009 05:33 AM
05 STi stereo question David03WRX General Community 3 05-08-2004 11:27 PM
STI Stereo Question for anyone WRC-STI Bay Area Impreza Club Forum -- BAIC 3 09-29-2003 02:10 PM
STI stereo question mazdman STi Forum Archive 10 07-16-2003 07:51 PM
STi Stereo Wiring Harness Question bcristea STi Forum Archive 2 07-14-2003 11:08 AM
