Old 09-07-2003, 07:02 PM   #1
psycho2.5rs
Member#: 36727
1998 impreza 2.5 rs
black
Default 22b
need some opions, should i turn my 2.5rs into a 22B look alike or try for the H6 engine? if i go with the 22B idea what do i need to do to my enigne to make it the same or close to?
psycho2.5rs is offline   Reply With Quote
Old 09-07-2003, 11:55 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Well the ej22T is the 22b block. As for heads with some work you can use whatever you want. I was thinking of going with a ej22T and some new age sti heads with the avcs. As for internals the stockers are good for 15-20bs of boost with a good mangement.
As for the H6 why??? It doesnt make sense. To me at least...
Old 09-08-2003, 12:58 AM   #3
psycho2.5rs
Member#: 36727
1998 impreza 2.5 rs
black
yea that is what i want some opinions
so there is a 2.2 block it isn't just 2.5 block with a 2.0 head. then where do u get the egine, plus i plan on running a very large turdo (and some other special mods) so what are some good internals?
Old 09-08-2003, 01:17 AM   #4
vovo
Member#: 33742
2002 Wrx Sportwagon
WR Blue
i got a large turdo myself
vovo is offline   Reply With Quote
Old 09-08-2003, 01:34 AM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
well if your going to run huge power... Id get a block from cobb, axis, or I-speed.
no the ej22 is a 2.2L... make sure you get the tubo motor the n/a ej22 is a different motor. You could get a 2.0L jdm sti motor lots of fun to be had with that.
I dont have a large trudo.... just a small one but Im not looking for over 300whp. I mean how much power do you need in a daily driver? If I were to build a track car I would use a motor from one of thoes tuners.
Old 09-08-2003, 02:13 AM   #6
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
the ej22T came in the legacy turbos in the early 90's they made around 165 stock i believe but the block is closed deck and nearly indestructable...
you'd probably be better off with the ej25T from a forester xt, bumping it's HP, getting a 22b widebody kit 22b replica wing, and some recaros...
keep in mind nobody can order 22b parts from subaru but 22b owners
nomadtw is offline   Reply With Quote
Old 09-08-2003, 03:03 AM   #7
psycho2.5rs
Member#: 36727
1998 impreza 2.5 rs
black
****, no one can get 22b parts but the owners. oh well i will get as close as i can with it.
u all are good but where can i get a wrx2.0 head? and who is the best company for getting parts?
Old 09-08-2003, 09:27 AM   #8
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
the 22b is an ej20 overbored to a 2.2...
from www.22b.com
The engine was bored out to 2.2 litres, retaining the same stroke as the stock 2.0 litre engine.
and
STi takes the engine and bores out the normal 2 litre lump to 2.2 litres. This will allow more torque at lower revs.
DanzBorin is offline   Reply With Quote
Old 09-08-2003, 12:07 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
usdm sti 2.5 is > 22b engine in alomst every respect.. plus it runs on 91 octane..
Old 09-08-2003, 12:14 PM   #10
DanzBorin
Member#: 7131
2015 Outback - Croc
and it's way cheaper...
Old 09-08-2003, 01:53 PM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
ok... its been coverd before the ej22 is the 22b block. It would make no sense to overbore a ej20g or k when they already had the ej22 a 2.2 liter fully closed deck.
As for the new sti ej257 being cheeper... I dont know. I was qouted the same price for the short blocks. As for it being stronger then the ej22 blocks... we dont know yet but things are not looking good... The pros are talking about the deck itself being the weak part on the ej257, the ej22 deck is hardly a problem at any level.
http://forums.nasioc.com/forums/show...68#post4553668
As for what heads to go with... you could pick up a set of ver7 sti heads or get some used wrx heads and get them worked over by a shop you trust.
Now like I said before If you want big power
http://cobbtuning.com/wrx/engineblock.html
http://www.axispowerracing.net/services.html (they also have used jdm sti parts, www.rallispec.com has sti parts new)
http://www.i-speed.us/products/ (crazy 2.8L block!)
Old 09-09-2003, 08:20 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I would use the EJ22T for cost and ease of use. The body parts are made aftermarket. I think Aerosims research is developing a real nice kit right now. Not sure if it's done. The wings can be found all over the place. Get the STI scoop and try to find some real 22B vents. They're larger than all of the replicas floating around. Of course the drivetrain work will cost a ton. As you can see I have thought of doing this but being a college kid and all the money is hard to get. I wish the best of luck to you.
take it easy, Micah
Old 09-10-2003, 01:40 AM   #13
psycho2.5rs
Member#: 36727
1998 impreza 2.5 rs
black
well me too, ASU but i don't plan on doing it right away, i plan on 10 years max. but thanks yea all for the info, helps out
peace
james
Old 09-10-2003, 10:21 PM   #14
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
well im putting in an ej22t with a ludespeed stage III kit and at 10 psi ive been quoted numbers at about 260-280AWHP...daily driver at 400 hp to the crank. The block is able to hold 22psi and is supposedly good too some 750hp if done right. Im going to keep it at a good daily driver and try and run it at like 5 psi and only turn the psi up when im on the track or auto-x'ing.....
ill turn it all the way up when im street racing and using my nawz also!
Steve
SpamMansXe is offline   Reply With Quote
Old 09-10-2003, 10:22 PM   #15
SpamMansXe
Member#: 15920
1999 White Mock 22B
eventually, in a couple years when i can afford it...im getting a widebody 22B kit and rims to match....ooo having 9 inch wide rims will be amazing!
Old 09-11-2003, 12:08 AM   #16
psycho2.5rs
Member#: 36727
1998 impreza 2.5 rs
black
i would like to do the same, the engine and the wide body kit but no money!
james
Old 09-11-2003, 01:32 AM   #17
SpamMansXe
Member#: 15920
1999 White Mock 22B
ya the kit is going to be like 10 times more expensive then the engine and turbo...it took me a while to get the engine and kit so i imagine it will be a lil before i get my 22b kit..
Old 09-11-2003, 01:50 AM   #18
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
by christmas I will have as close as your going to get to a 22B motor, w/o stealing one- 2.2L close deck DOHC motor
Scoobyslack1 is offline   Reply With Quote
Old 09-11-2003, 05:33 AM   #19
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Yeah
Steve
Werd!
Kevin Thomas is offline   Reply With Quote
Old 09-11-2003, 10:39 AM   #20
SpamMansXe
Member#: 15920
1999 White Mock 22B
Default Re: Yeah
Originally posted by Kevin Thomas
Werd!
Old 09-14-2003, 07:33 AM   #21
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
LOL and its still slower than the JDM 2.0L in the 1/4.
DuoMaxwell is offline   Reply With Quote
Old 09-14-2003, 10:07 PM   #22
totoherbs
Member#: 7321
.... 122 IggPoints
and making less power then the spec c's 2.0
the 2.5L deck is hardly half as strong as the ej22T
Old 09-15-2003, 12:42 AM   #23
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I seen a 22B engine on Yahoo Japan about two weeks ago. Looked good low milage they wanted 930000 yen. That is around 8gs for the thing!!!
Old 09-15-2003, 11:11 AM   #24
SpamMansXe
Member#: 15920
1999 White Mock 22B
hell ya!
Steve
EJ22T RS
Old 09-15-2003, 09:30 PM   #25
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
how much do you think it would cost to put a wannabe 22b motor together...
ej22t block - $1000 ? ?
anyoen care to add to the list
scoobyimpreza is offline   Reply With Quote
22b front bumper with grill, 22b side skirts, 22b rear bumper, and Cwest front bumper D Spec Dc2 Private 'For Sale' Classifieds 51 05-17-2005 06:20 PM
looking for 22b wing or 22b replicar for gc8 scoobyruman Private 'Wanted' Classifieds 0 09-23-2003 02:26 PM
('93-'01) ANOTHER 22b spotted!!! How many 22b is ther world wide!?!?! limited ? gerardchau Impreza Forum 23 08-07-2001 02:27 AM
('93-'01) Where are the 22bs closest to America? MichiganRS Impreza Forum 17 05-17-2001 10:24 PM
('93-'01) 22B Displacement bryanw Impreza Forum 13 05-09-2001 12:37 AM
