Old 09-07-2003, 10:06 PM   #1
Keith Cournoyer
Member#: 16764
Default O2 sensor in MRT Header
Hi Folks,
I have a question for those of you who have the MRT Header on there RS:
For the 2nd O2 sensor, what is everyone doing for lengthening it to make it long enough to fit?
The reason I ask is that I spliced my old O2 sensor to a new one I purchased. It worked for a while, but recently I have being pulling a trouble code that says the 2nd O2 sensor is not functioning. I am wondering what my options are for fixing this problem? I need to get an inspection soon and need to act soon. Thanks in advance to any help or suggestions!
Keith
Keith Cournoyer is offline   Reply With Quote
Old 09-08-2003, 01:00 AM   #2
obyone
Member#: 16523
I had the shop lengthen the O2 sensor wires, when they installed my MRT system, but I've heard that there is a plastic quick zip/wire tie that can be removed to give you the extra length. The wire tie is pretty far on the engine so you'll have to follow the wires to find it.
If you lengthen the wire, get some good quality connectors. I've also heard that the wires used for the O2 sensor are coated to protect against the elements, thus they cannot be soldered correctly.
obyone is offline   Reply With Quote
Old 09-08-2003, 11:06 AM   #3
kickin_81
Member#: 16679
2004 Forester XT
Yup! The bundle is tied under the area of the airbox. Just follow it, and you'll find it in no time. I actually had my brother help me, so he was the one who untied it. He didn't use any tools to untie it, so it should be fine by yourself (assuming you have the car secured on jack stands/ramps/raised). Have fun with the better pull.
kickin_81 is offline   Reply With Quote
Old 09-08-2003, 11:58 AM   #4
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I've got an 01, and my CEL has been on since I installed my MRT. People are right, you do have to release that one wire from the bundle in order to have enought slack in the line to attach the 02 sensor. Good luck, I've since bought a pony express mil eliminator, but I've yet to install it.
AO
m750 is offline   Reply With Quote
Old 09-08-2003, 02:42 PM   #5
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Does the 02+ model year have the extra wire available to connect the second 02 sensor? I have a constant CEL from TWE headers and hi-flo cat that I would like to go away.
Jard is offline   Reply With Quote
Old 09-08-2003, 04:38 PM   #6
Keith Cournoyer
Member#: 16764
Default 2nd O2 sensor
Thank for the info everyone. I have had the header on for a while now, yes it pulls nicely! I too have the Pony express eliminator but need to get a new O2 sensor first before installing it. Does anyone have any experience with non-OEM oxygen sensors? I know they're a little less expensive.
Keith
Old 09-09-2003, 01:53 AM   #7
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
Originally posted by obyone
.....the wires used for the O2 sensor are coated to protect against the elements, thus they cannot be soldered correctly.
Enameled wire can be soldered if you use a broad tip, 800+ degrees. You just have to cook it with the iron for a few seconds more than normal to burn off the enamel.
Andrew Bacon is offline   Reply With Quote
Moving o2 sensor into the header... HamFist Normally Aspirated with bolt-on Forced Induction Powertrain 2 01-09-2010 11:32 AM
Rear O2 sensor and MRT header Keith Cournoyer Normally Aspirated Powertrain 10 07-20-2008 07:43 PM
Which Impreza's have O2 sensors on the header? rougeben83 Normally Aspirated Powertrain 3 04-26-2008 05:06 PM
O2 Sensor in stock header question NoFriends7 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-09-2006 08:54 PM
Complete Sti turbo kit with O2 sensors/ UP/DP/header BistroSti Mid West Subaru Owners Club Forum -- MWSOC 3 08-22-2004 07:15 PM
