Old 09-08-2003, 10:04 AM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default TMIC and Throttle Cable Issues
i know there has been some fitment issues and i havent tried putting mine in yet, but i wanna here from people that have OEM WRX intercoolers on their turbo projects and what BOV they are using and if they are having any fitment issues with the throttle cable. i plan on using an OEM TMIC and an OEM BOV. will that fit in there alright? thanks everyone!
Brent
scoobyimprza is offline   Reply With Quote
Old 09-08-2003, 01:14 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i believe the forge will fit
the other option is to buy a wrx bov flange (they are avaiable) connect a hose to it and mount a bov remotly
Old 09-08-2003, 02:05 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
does the OEM BOV fit though?
Old 09-08-2003, 06:31 PM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Do you need an intercooler or do you have one already? I have one if you need it.
garface is offline   Reply With Quote
Old 09-08-2003, 07:42 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
with a 1.8 throttle body
no
Old 09-08-2003, 08:33 PM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
i have a 2002 OEM wrx intercooler right now, just not installed yet. i guess i'll look for an adapter plate. thanks guys!
Brent
Old 09-08-2003, 08:35 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Surprisingly your best bet is to look over at the Legacycentral BBS. (first generation legacy)
Since its the only turbo subaru as your generation of vehicle we had the same problems. We have found a couple intercoolers that fit.
http://bbs.legacycentral.org
Old 09-08-2003, 09:26 PM   #8
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
I had to mill down the intercooler, to get it to fit without hitting the firewall. I'm using a GFB 50/50 with no problems. It clears the throttle linkage. I did remove the cruise control portion of the throttle linkage, but I don't believe that it was a must. It probably would have fit anyway.
Some pics can be found here
http://www.rs25.com/forums/showthrea...&threadid=9053
or here
http://forums.nasioc.com/forums/show...hreadid=153798
Hope this helps.
scubydrew is offline   Reply With Quote
Old 09-09-2003, 09:14 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I dropped the cruis control unit (not needed). the stock TMIC and a GFB 50/50 BOV and the stock cable all in use with no problem except that I had to mount my old cable mount onto the new one (via bolt). I had to bend the old one slightly but i t fits fine.
Hope this helps, Micah
2.0 cable and Romraider logging issues??? jblackwell Open Source Reflashes 6 12-01-2008 06:47 AM
Detaching throttle body from throttle cable..how? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2008 02:28 AM
wtb: sti throttle cable and brake lights switch darkmist2k1 Private 'Wanted' Classifieds 1 05-20-2008 02:23 AM
Throttle cable problem and info hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-22-2007 02:41 AM
Baffled by cable issues and so is Comcast. MK19_ Off-Topic 26 04-30-2007 11:49 PM
