Old 09-07-2003, 04:01 PM   #1
leecea
Member#: 37359
2003 WRX
Default Quick alignment question
The alignment shop forgot to tighten to this nut on the driver's side - it was half-way up the threads when I looked under the car today. I have driven for about 2 months like that, including 3 autoXs.
I tightened it myself today, but do you think the alignment could have gone bad in that time?
I really don't want to go back to the alignment shop unless I have to.
leecea is offline   Reply With Quote
Old 09-07-2003, 05:35 PM   #2
esteve
Member#: 28716
2006 STI
Yes, you should take it back to the shop because the toe might've changed.
Some guys leave the nuts loose to get a print or save the readings and then tighten them afterwards because the toe tends to change as you tighten the nut.
esteve is online now   Reply With Quote
Old 09-08-2003, 10:28 AM   #3
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Your picture shows the tie rod, which is how toe is adjusted in the front
In your picture, the threaded rod on the right threads into and out of the rod end on the left to give you more or less toe in/out. The nut is tightened to the rod end on the left.
Are you saying that the nut wasn't tight against the rod end on the left? If that's the case, then there's a good chance that your toe settings have floated.
How's your tire wear? Driving down a flat, non-crowned road, is the steering wheel straight?
Austin is offline   Reply With Quote
Old 09-08-2003, 10:30 AM   #4
leecea
Member#: 37359
2003 WRX
Thanks for the help.
Yes, the picture is after I tightened the nut myself. The wheel sometimes seems a little off center but other times is fine. I have heard all this memory steer stuff and am not sure if that's what I'm seeing.
It haven't seen any obvious tire wear problems yet.
If I take it back, it will be the third time at the alignment shop just trying to get it right I guess I need a different shop. I wish I could do it myself. Maybe I'll experiment a bit.
Old 09-08-2003, 10:46 AM   #5
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
You can do it yourself.
Look Here.
Old 09-08-2003, 11:33 AM   #6
leecea
Member#: 37359
2003 WRX
Many thanks. I like the string based adjustment. I looks better than the gauge. I think I'll try making some measurements that way.
Quick alignment question gling Brakes, Steering & Suspension 5 04-21-2010 10:48 PM
quick alignment question NMZ_WRX Newbies & FAQs 5 03-24-2010 06:19 PM
Quick Track alignment question.... TubeDriver Brakes, Steering & Suspension 3 07-26-2005 02:12 PM
Quick Alignment question! GregsblueRex Brakes, Steering & Suspension 4 07-31-2003 01:15 AM
quick alignment question loreley Newbies & FAQs 1 05-26-2003 10:19 PM
Message Board Statistics All times are GMT -4. The time now is 03:07 AM.
