Old 09-08-2003, 03:32 PM   #1
tjhenn
Member#: 32333
2003 Impreza TS
Green
Default PCV on 2003 TS
Does anyone know where the PCV is on the 2003 Impreza TS? I've seen some posts here and at Scoobymods that show it being behind the coil pack, under the air filter, but when I took that out, it looked nothing like the Purolator PCV I bought (PV1019). It was just a threaded tube with a nipple on one end for the vacuum hose. There was also mention that it was in the front of the engine. I'm not sure if that was it because I couldn't get it out with out removing the alternator. It looked like it had a selonoid on it. Is that the PCV? Also, how often does it need to be changed? I thought I'd do it when I was doing everything else at the 15,000 mile service, but if I can't get it out, it may have to wait until I take it to the dealer for the 30k mile checkup.
Thanks!
tjhenn is offline   Reply With Quote
Old 09-09-2003, 07:52 AM   #2
DaveM
Member#: 4503
2012 Imp Sport Ltd
Camellia Red
The PCV valve is at the other end of the hose screwed vertically into the engine block.
DaveM
DaveM is offline   Reply With Quote
Old 03-08-2004, 10:14 PM   #3
tomkang2000
Member#: 34993
2003 Impraza 2.5TS
Default PCV Valve Part #
the PCV Valve on 2003 TS is different from other imprezas; I don't think PV1019 will fit; OEM part # is 11810AA040;
tomkang2000 is offline   Reply With Quote
Old 03-09-2004, 12:31 AM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
PCV Valve mania seems to have gripped the Service & Maintenance forum.
Nothing wrong with that though since it is fairly important for emissions (and lately fuel mileage). It's also relatively inexpensive for a maintenance item too ($2 from Kragen/Autozone, $6-7 from the dealer). I think it's something they should have put in the service manual though.
http://www.scoobymods.com/forums/sho...ight=PCV+valve
It's usually towards the back of the intake manifold.
[you're lucky you don't have an intercooler getting in your way...]
-Henry
Old 03-09-2004, 01:34 PM   #5
tjhenn
Member#: 32333
2003 Impreza TS
Green
Like Tom said, I'm not sure its the same PCV valve as the WRX. When I took off the hose to look at it, it was just a hollow threaded tube with no valve in it, not like part PV1019. I haven't changed it yet, waiting until my 30000 mile maintenance. Probably have to talk to the parts guy at the dealer.
Thanks!
Old 03-21-2004, 06:16 PM   #6
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
I ran into this today when trying to change mine, only to discover it was just a hollow tube (and smaller in diameter than the replacement Subaru part I bought). It was in this location, but no clip:
Do the 2003 NAs have one that needs to be replaced?
Cabal is offline   Reply With Quote
Old 08-08-2004, 02:03 PM   #7
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Bump for an answer!
Do 03 NAs not use PCV valves somehow? I guess it's plausible that a robust enough IAC system and a speed density fueling system could make it possible to implement PCV without a PCV valve...
vrg3 is offline   Reply With Quote
Old 08-09-2004, 03:25 PM   #8
sj72
Member#: 47399
I have the same question on a 2002 Legacy GT 2.5 NA.
I have checked the locations provided by ScoobyMods and this forum. I have a valvle screwed in to the engine behind the coil pack pointing towards the passenger side.
I purchased Purolator PV1019, but the PCV I see on my car is nothing like the Purolator valve. Just a threaded tube with a nipple hole at one end.
I took off the "valve", sprayed Carb cleaner through it and used foam swabs to clean out the residue inside. It came pretty clean, so I applied a little teflon tape to the threads and resealed. Can't say I noticed a huge difference, but RPM's may have dropped every so slightly in idling.
Any help on identifiying if the 02' and up 2.5 engines do have a PCV, and the proper part number is appreciated.
sj72 is offline   Reply With Quote
Old 08-10-2004, 01:18 PM   #9
tjhenn
Member#: 32333
2003 Impreza TS
Green
I haven't heard a definative answer yet, but I can't see anything else on the NA 2.5's that look like the PV1019. So I guess I'm just going to assume that the NA engines don't use the typical PCV.
Old 08-12-2004, 09:06 AM   #10
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
Hmm.. I have an '02 TS and replaced my PCV at 30k miles. I believe the 2003 is identical. As I recall the PCV was at the top of the motor, pretty much like the photo above. Might have to remove the airbox, I can't remember without looking at it.
Either way, it took about 5 minutes to replace.. And if you let it go to 60k miles (or maybe even more), it shouldn't be a big deal.
LordBass is offline   Reply With Quote
Old 08-12-2004, 07:19 PM   #11
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
Perhaps they changed it for 03, mine definitely has the hollow tube as located in the picture above. Maybe I'll get a dollar for the unused PCV at the next meet.
Old 03-16-2005, 12:27 PM   #12
sfsubaru
Member#: 21901
2003 Forester 2.5X
Platinum Silver
Question Have you changed the PCV valve yet?
Have you changed it yet? I'm planning to do mine soon on my 03 Forester X. As DaveM said, it looks like it's screwed vertically into this swivel piece inside the engine? block. On mine you need a long socket extension, probably 10 inches total reach to get to the PCV valve. The tricky part would be to finagle a 21 or 22mm wrench down there to hold on to the swivel piece so you can unscrew the PCV valve. Do you have any tips to do this?
Thanks!
sfsubaru is offline   Reply With Quote
Assorted Suspension/Braking bits from 2003 TS Wagon and 2003 WRX Wagon: stoney98 Suspension/Brakes/Handling 5 07-09-2008 02:29 PM
2003 TS wagon/STi version 7 swap: Emission test results Kreeger Subaru Conversions 11 05-25-2006 12:55 PM
wrx 02/03 16" rim will fit into 2003 ts wagon? concentration Tire & Wheel 1 09-20-2005 10:50 PM
2003 TS wagon widebody? Migo Interior & Exterior Modification 9 06-30-2005 10:45 AM
Fs: 2003 Ts 2.5 solomrus Private Vehicle 'For Sale' Classifieds 8 11-24-2003 12:30 PM
