View Poll Results: How often do you cahnge your synth oil?
1-3k 1 0.60%
3k every time 84 50.60%
5k 58 34.94%
5-10k 23 13.86%
Voters: 166. You may not vote on this poll
Closed Thread
Old 09-08-2003, 06:20 PM   #26
Wheeldog
Member#: 19848
2002 WRX Wagon
I use Amsoil XL-7500 5W30, and change it every 3750-4000 miles. It always looks pretty good (light-colored) even at 4k miles, and I'm pretty sure I could get away with a longer interval. I think 3k or less is really overkill for a daily driver and with a good quality full synthetic.
Wheeldog is offline
Old 09-08-2003, 06:59 PM   #27
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Originally posted by kenshiro
I change every 3K and by that time the oil is always very black and gross.
Oil turns black by being run through the engine. You should have black oil almost all the time as that is the way it reacts to the heat and use.
The Subaru manual for changing oil says every 7500 miles and that is for the dyno stuff. Synthetic should last much longer!
An example of this is a friends corvette. It runs about 13 flat in the 1/4 and has an indicator to tell you when to change your oil. His synthetic lasts about 20,000 miles between changes. He was a little uncomfortable going that long and talked to the service department about it. Their response, "that's about normal for all of our vettes".
The oil companies have spent a fortune trying to scare people into changing their oil every 3,000 miles. It just isn't necessary for the overwhelming majority of cars.
HerculesPeanut is offline
Old 09-08-2003, 07:05 PM   #28
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
i dont buy it. if my car can burn up or loose 1 qt of oil every 2-2.5k miles i sure as hell am not going to keep that crap in my car for 7.5 or more k miles. 1) because there wont be any left so i might as well enver change oil beacause by then i would have poured in 3+qts of oil. 2) because the oil might be ok but there are also pieces of carbon and other crap in the oil that the filter doesnt pick up.
D-I-Z-Z-L-E is offline
Old 09-08-2003, 07:19 PM   #29
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
First, if you are burning that much oil then there is something very wrong with your car. This is no longer an issue of how long does the oil last, it is an issue of how much longer will your car last.
Second, why not just add a quart when it gets low and you will keep a supply of fresh clean oil coming into your car negating the need to change it?
Old 09-08-2003, 07:23 PM   #30
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
well according to subaru 1-1.5 quart loss is normal for the wrx. as for any other car manufacturer. and i can add oil but i dont want it all mixing in with the gunk and stuff. so i will be safe and change my oil every 3k. just like i have done. if my oil wasnt being consumed i might go for 5k
Old 09-08-2003, 07:29 PM   #31
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
How are you measuring oil consumption?
driggity is offline
Old 09-08-2003, 07:40 PM   #32
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
well i check the dipstick its almost all teh way down. i fill it up about a quart. and its full. thats how i do it
Old 09-08-2003, 07:51 PM   #33
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Are you checking when the engine is cold? If I remember correctly the owners manual says to check when the engine is warm and there is a very noticeable difference in the warm vs cold level if you check with the dipstick.
driggity is offline
Old 09-08-2003, 07:53 PM   #34
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
cold. but i go off of when i put the oil in . let the car cool off and its cold. i check it and its full. tehn i let it cool off later on down the line when its cold and its almost all the way down. like on the tip of the dipstick
Old 09-09-2003, 08:49 AM   #35
modvp
Member#: 25215
I change every 5k with Mobil 0W/40.
modvp is offline
Old 09-09-2003, 09:17 AM   #36
Rich10
Member#: 14934
I change every 3,000 miles with Mobil1. I use 10w/30 in the summer and 5w/30 in the winter. The oil still looks good when I take it out of the car and I don't lose any oil. The oil would very likely be good for more than 5,000 miles but for the minor cost, it is a good investment. It also give you an excuse to look under the car more often.
edit for spelling
Rich10 is offline
Old 09-09-2003, 10:03 AM   #37
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
I do 10k with AMSOil. While it is dark when it comes out, it is still flowing quite well. Over 10K I lose ~1 quart. I'm at 42,000 miles.
Something to ponder:
http://neptune.spacebears.com/cars/s.../oil-life.html
Tom
SlideWRX is offline
Old 09-09-2003, 10:15 AM   #38
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
realistically it's between 3-5K for me. though normally it's closer to 5. it's becoming a little less since I don't drive the scooby much anymore.
oil is always fine for me, and I didn't really lose any oil, though I haven't changed it since my seals went in the turbo- it was a fresh change anyway
slide- pretty interesting write up
speed safely
Brian
Slvrblt is offline
Old 09-09-2003, 10:33 AM   #39
Reverend
Member#: 33354
98 Supra TT
black
Here are my thoughts....
Engine oil provides 4 basic functions:
* lubricate the internal moving parts (duh)
* help seal the piston rings
* helps cool the engine
* clean the carbon deposits from the moving parts
I can see an oil doing 3 out of these 4 things for up to 20k miles, but I just can't see oil efficiently cleaning the carbon deposits past 3-5k miles.
Just my $.02
Reverend is offline
Old 09-09-2003, 11:31 AM   #40
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
Tom
AWSOME FIND thank you
Old 09-09-2003, 02:01 PM   #41
5-speedfreak
Member#: 37765
I'm about to do my 2nd oil change on the wrx.... First change was at 1k (switched to Motul synthetic). I'm on my 2nd change at 4k and I'm going to try new stuff on the market.
Turbonetics has a new oil. My friend who works there uses this oil in his stage 4 300zx T/T and highly recommends it.
I cut/pasted this from their site....
Turbonetics TS-1 Technology Driven, Competition -Proven Synthetic Performance Motor Oil is formulated to provide superior protection for gasoline engines under extreme, demanding conditions. Engineered with unique additives, TS-1 Synthetic Performance Motor Oil offers outstanding high-temperature control properties and helps reduce engine wear.
This 100% synthetic oil (full PAO) exceeds conventional oil requirements and delivers the ultimate in engine protection for forced-induction (turbocharged / supercharged) and naturally aspirated gasoline engines. Excellent for high-performance street and race engines. Exceptional for severe situations such as towing, stop-and-go driving and prolonged idling.
* Contains VisTech , an exclusive technology-driven, competition-proven agent that provides a protective barrier for critical bottom-end components.
* Blu-Ester top-treat provides better coefficient of friction thereby unleashing additional horsepower.
* AFX 3 foam-inhibitor minimizes frothing and overflow - vital to turbo/high-performance applications.
* Compatible with conventional engine oil and suitable for top-off and service fills.
* Viscosity index of 175.
* Flash point above 450F.
* Meets and exceeds API Service SL.
thoughts, comments, anyone tried it yet?
5-speedfreak is offline
Old 09-09-2003, 02:25 PM   #42
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
Originally posted by 5-speedfreak
I'm about to do my 2nd oil change on the wrx.... First change was at 1k, 2nd change at 4k. I switched to synthetic at 1k.
I'm going to try Turbonetics new oil. My friend who works there uses this oil in his stage 4 300zx and recommends it.
thoughts, comments???
that really wont mean anything to anyone unless someone has used it and knows that oil.
Old 09-09-2003, 02:34 PM   #43
5-speedfreak
Member#: 37765
After I use it, I'll let you know what I experience. Turbonetics has an excellent name in the industry, and if they stamp their name on it, I'm sure that it will be good.
Stay Tuned...
Old 09-09-2003, 03:21 PM   #44
redhat778
Member#: 34184
02 WRX
Now with STI VII Swap
I change my oil every 3k miles exactly with mobile1. I really don't care if it is a gimmick. it makes me feel much better to know that i have fresh oil in my car.
redhat778 is offline
Old 09-09-2003, 03:35 PM   #45
STEALTH-WRX
Member#: 7822
Multi layer snot green
I havent changed mine in 23,000 miles. Who cares its just a car.
STEALTH-WRX is offline
Old 09-09-2003, 03:37 PM   #46
Reverend
Member#: 33354
98 Supra TT
black
LMAO
Reverend is offline
Old 09-09-2003, 03:45 PM   #47
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Mobil 1 every 3,750, as the manual recommends for severe duty. It may be over kill, but it is cheap peace of mind.
I can't help but notice your poll doesn't have the option for either factory recomended drain intervals: 3,750 or 7,000.
Stanley is offline
Old 09-09-2003, 04:53 PM   #48
simwahWRX
Member#: 20870
Midnight Black mica
quote:
Originally posted by simwahWRX
Was going 3k, then I had my oil analyzed. The lab said I'd even be safe at 6.5K, but I now do 5K, anyway.
what brand? mods? what type of driving?
Mobile1 5W30
Cobb Club Spec, plus APS SR30 turbo, TMIC, AccessECU (RT Spec)
Moderate driving (don't go over 6K rpm more than 3-4 times a week)
oil analysis (prior to turbo and AccessECU):
4,888 miles (0 make up added)
TBN 13.0
Aluminum 3
Chromium 1
Iron 7
Copper 1
Lead 2
Tin 1
Molybdenum 71
Ni 0
Manganese 0
Silver 0
T8itanium 0
Potassium 0
Boron 175
Silicon 6
Sodium 9
Ca 2840
Magnesium 15
Phosphorous 747
Zn 971
Barium 0
viscosity 58.5
Flashpoint 385F
Fuel <0.5
Antifreeze 0%
Water 0%
insolubles 0.4
28.4mpg on Shell 93 octane
simwahWRX is offline
Old 09-09-2003, 05:56 PM   #49
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
It is normal for the flat 4 to eat oil between oil changes. If you start to consume large amounts then you better start to worry.
I am usually about 1-1.5qts lower between 3K oil change intervals.
3K changes with Mobil 1 and sometimes Amsoil.
Need4Boost is offline
Old 09-09-2003, 06:54 PM   #50
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I check my oil at every fill up and the car has yet to use any perceptible amount of oil in 36K miles of driving. Therefore I would argue that while it may not be *uncommon* for the flat 4 to use some oil (or any gas engine for that matter), it is not "normal".
I know it is very common for BMW engines to use oil, especially the higher performance models.
Stanley is offline
Closed Thread
How often do you change your oil?... Hazdaz Off-Topic 56 04-02-2007 06:37 PM
How often do you change your oil? wyn525i Off-Topic 58 12-23-2006 01:08 PM
How often do you change your oil? Chris51080 Service & Maintenance 14 04-23-2003 07:52 AM
How often do you change engine oil with synthetic oil? malelee21 Service & Maintenance 53 04-14-2002 10:33 AM
Newby question, how often do you change your oil? SteveGood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-21-2001 02:53 PM
