View Poll Results: How often do you cahnge your synth oil?
1-3k 1 0.60%
3k every time 84 50.60%
5k 58 34.94%
5-10k 23 13.86%
Voters: 166. You may not vote on this poll
Closed Thread
Old 09-09-2003, 07:36 PM   #51
Stilletto
Member#: 21866
2002 WRX Silver
13.82 1/4 Almost Stock
I have been anywhere from 3 to 7000k between changes...
I have never noticed any loss of oil whatsoever in using dyno or synth....
It always stays exactly at the same level on the dipstick.....and thats for 41k miles now...go figure...
And i have never driven my car any other way but FAST
Stilletto is offline
Old 12-03-2012, 04:53 PM   #52
supafastR
Member#: 161335
Around 10-15K....
Used to be M1 0w-40 until that changed, now Shell Rotella T6 5w-40.
I have to add a quart every thousand or so (prob. need a turbo rebuild), but so far so good.
Make sure you have very high quality filters if you go this route...
Livin' on the edge
supafastR is offline
Old 12-03-2012, 05:16 PM   #53
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Wow.
bushflyr is offline
Old 12-03-2012, 05:51 PM   #54
02redwagone
Member#: 87067
02 Old but tasty
SRP
8-10k with labs. No adding. RT6/ purolator filter. Every motor is different. Do your own research...or dont.
02redwagone is offline
Old 12-03-2012, 06:10 PM   #55
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I generally burn/leak so much oil that I only ever need to fill the car. It changes itself automatically. It's what makes a Subaru, a Subaru.
kpluiten is offline
Old 12-03-2012, 06:29 PM   #56
Andrewxxcarlson
Member#: 316415
2006 WRX
^^^ sigh
Andrewxxcarlson is offline
Old 12-03-2012, 07:22 PM   #57
CalvinT
Member#: 329025
2002 WRX Wagon
I think anyone who changes every 3K without having their oil analyzed is wasting money. Blackstone charges $30 to do an analysis. Just pull a sample every 3K and have it analyzed. I think most will find they can go up to a year between changes if they're using a good synthetic.
CalvinT is offline
Old 12-03-2012, 08:13 PM   #58
ogboot
Member#: 170906
psm
For $30 you can almost, if not actually change the oil. Subaru updated the recommended interval for the older chassis' to 3750 miles for turbocharged engines. I can't speak for 08+, tho. It used to be 7k but they cut it in half
At 3k I start thinking about it, and it's done somewhere between there and 4k every time. Sure the oil likely has some more life, but they recycle it nowadays at least and that's not a whole lot of miles from what's recommended by the MFG.
Having said that I will also occasionally get a UOA from Blackstone, but it's a health check.
ogboot is offline
Old 12-03-2012, 08:30 PM   #59
hoffmanEstates
Member#: 122043
04 wagonier
psm
6-8k. On amsoil
hoffmanEstates is offline
Closed Thread
How often do you change your oil?... Hazdaz Off-Topic 56 04-02-2007 06:37 PM
How often do you change your oil? wyn525i Off-Topic 58 12-23-2006 01:08 PM
How often do you change your oil? Chris51080 Service & Maintenance 14 04-23-2003 07:52 AM
How often do you change engine oil with synthetic oil? malelee21 Service & Maintenance 53 04-14-2002 10:33 AM
Newby question, how often do you change your oil? SteveGood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-21-2001 02:53 PM
