#1 |
Member#: 43093
My girlfriend's brother just picked up a 95 Legacy Wagon, 164k, for a real good deal - 2500 bucks. The car has been babied it's whole life, and is loaded. Unfortunately since buying the car, it has stranded him a number of times. At first we thought that this was a battery/alternator problem, but it seems to be something else. We replaced the battery and checked the alternator... everything looks good. His mechanic can't figure it out, so it seems like the next step might be to take it to a stealer, but that idea gives me the willies.
The car just won't react when you put the key in the ignition and turn it. There is power there, but no starter action. However, the car sometimes will start if you move the shifter a bit, or will start later on. It just doesn't start when you want it to. Does anyone have any idea what this could be? I'm thinking that there may be some sort of problem with a switch in the transmission, or perhaps an ignition switch problem. I'm not at all subaru-savvy, I drive a diesel VW - it's a completely different animal! Any help or suggestions you folks could give would be much appreciated. The owner of the car is a poor 18-year old and doesn't have the money to let the dealership toss parts at it.
#2 |
Member#: 13110
NESIC
Next time the car wouldn't start, try putting the transmission in "Neutral" and try to start again.
Sounds like the neutral safety switch is on its way out. |
#3 |
Member#: 43093
that was my thought as well.
do you know how difficult a part that is to replace? i'd love to be able to do this myself so he doesn't have to spend more money. poor kid had to replace the windshield and the o2 sensor right off the bat. i was able to do the o2 sensor for him no problem, but again, i know nothing about subarus (except that i want one as a second car). thanks! |
#4 |
Member#: 13110
NESIC
If it is indeed the neutral switch, you don't necessarily have to replace it.
(sorry I can't help you with the details about replacing it. Time to go check out those repair manuals in the bookstore) |
#5 |
Member#: 7497
Vehicle:2002 WRX WR Blue |
My gf had the same problem with her Sentra SE-R. She has to either put the lever to N or P and push it all the way up.
We were worry at the beginning but used to it now. no biggy. |
#6 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
It could be the relay contacts. The relay is still clicking but they are corroded so power doesnt pass.
#7 |
Member#: 43093
which relay are you referring to? i'll take a look at it.
i think i'm going to pick up a manual for the car. i'm not sure i understand why the neutral switch wouldn't have to be replaced, however. thanks for the help all. |
#8 |
Member#: 13110
NESIC
The neutral switch is there to prevent you from starting the car in gear.
So, as long as you remember to place the transmisson in Neutral, you don't really need the switch. |
#9 |
Member#: 17252
Vehicle:'06 WX8 59E |
With AT, there is a transmission "range switch" (a.k.a. inhibitor switch) but no separate neutral safety switch. The range switch can be adjusted which might help in case the problem is due to worn contacts. Pin-out and the adjustment procedure can be found in Haynes manual.
#10 |
Member#: 10642
Vehicle:95 Impreza EJ22T 05 LGT, 96 Outback |
If the car has a security system it could be the starter interrupt relay. It will cause an intermittent no-start problem. This is very common on the early SVX's.
-Jim |
| Thread Tools | |
| Display Modes | |
| 95 Legacy turns over but won't start | aldend123 | Normally Aspirated Powertrain | 7 | 03-05-2009 07:02 PM |
| 95 Legacy won't shift into 1st or 2nd gear? | highspeed11 | Legacy Forum | 4 | 02-27-2007 08:57 PM |
| Need help finding automatic trans for 95 Legacy wagon...what will fit?? | monger | Newbies & FAQs | 2 | 02-03-2006 04:53 PM |
| 95 Legacy LSi Sedan, AWD, Automatic, Leather, $1500 | ort5 | Private Vehicle 'For Sale' Classifieds | 0 | 12-13-2004 03:23 PM |
| 95 legacy rear defrost won't work! | lj17 | Legacy Forum | 10 | 10-31-2004 09:45 AM |
