Old 09-08-2003, 04:46 PM   #1
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Default Tapping for oil
I was reading somewhere that turbos do not need that much oil pressure. Is there any merit to this? I tapped my RS-T at the rear of the block, the secondary oil galley. How much pressure is coming from that spot? I had quite an oil leak that I could not pinpoint, could I have blown a seal with too much pressure?
Too late to ask now, but I was always wondering where the oil was coming from. There was always some dripping out of the intercooler whenever I took it off and held it upright.
wcbjr is offline   Reply With Quote
Old 09-08-2003, 04:50 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Oh, and I had a hefty oil return into a tapped pan. No blockage there.
Old 09-08-2003, 05:13 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, you could have seeping past the seals. I was the one that made the post about the pressure situation. Take a look :
http://forums.nasioc.com/forums/show...hlight=garrett
Old 09-08-2003, 05:17 PM   #4
jid2
Member#: 38853
03 EVO VIII white
97 OBS, 99 2.5 RS(T) SOLD
If you have oil inside your intercooler it's most likely blow-by and such from the valve train. When you pressurize your intake manifold and such you push oil back into the air take before the turbo, through the breather lines. That's why people run oil catch cans.
jid2 is offline   Reply With Quote
Old 09-08-2003, 05:19 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I had breathers and they weren't saturated.
Old 09-08-2003, 07:16 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yea the turbo doesnt need a lot of pressure i guess, oil is probably going past your seals i would guess, i think there is quite a bit of pressure coming off that second galley plug, because i just used a subaru plug with a couple adapters and one of the adapters split(i am assuming from the high pressure) and caused a leak. but when i put in the plug that came with the ludespeed kit there has been no problems, the difference is that the ludespeed plug had a significantly smaller hole, i talked to tom and he said that the hole shouldnt be any larger than .1" i believe it was, maybe even .01, anyone confirm? anyways i bet a restrictor would solve some of the pressure problems, maybe even the oil in the IC.
Ben
Old 09-08-2003, 08:10 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I used a plug with almost a 1/4" hole. I had another with a smaller hole but didn't use it.
I always had hesitation above 4 lbs of boost, maybe the problem was from oil getting thrown in the mix from the turbo. My solution was to get lower resistance plug wires and gap my plugs real small.
Old 09-08-2003, 10:32 PM   #8
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
I'm having the same problem with mine... but then again my turbo has 200,000 miles on it without a rebuild. I have a TD04L to put on, I just need the time to do so... As long as it's done before the SEMA show, I'll be ok.
Right now I'm running a -4 oil feed line, maybe a -3 would be better?
I love that banana... no matter how many times I see it, the thing just makes me smile.
Chad,
93 1.8T
subachad is offline   Reply With Quote
Where to tap for oil pressure gauge? joltdudeuc Normally Aspirated Powertrain 9 04-11-2006 09:46 PM
Tapping for oil scoobyimprza Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-29-2003 04:46 PM
Easiest place to tap for Oil Pressure guage. Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-13-2003 05:27 PM
tapping for oil temp/trans temp GimpWRX Bay Area Impreza Club Forum -- BAIC 0 11-29-2002 02:38 PM
Where to tap for oil psi gauge? STiShawn Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-12-2001 02:44 PM
