Old 09-09-2003, 09:15 AM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Default Best head swap for EJ22T Ver I?
I know the head isnt the best flowing on the EJ22T, so what should I replace it with? I'm building the motor for serious boost. Anything else I need to know about this motor before I start? Thanks.
Teh Legacy is offline   Reply With Quote
Old 09-09-2003, 03:40 PM   #2
serious
Member#: 22879
Serious boost? Hmmmm.....anyway, a lot of people will say the 2.5 heads are the only way to go. Personally i think they're on crack. Go and read the write up on the legacy forum about the swap. You'll find out they work, but not exactly how well most people think.
If you could find a wrx motor then you could use those heads and i guess they work pretty well. I'm considering this for my legacy.
Or you could just port the hell out of the current heads and make them flow better. I think this is probably the best choice, but you don't get bragging rights with it though. But then you'll have a hard time finding injectors with the fuel rails to work with serious boost.
The block uses cast pistons which you might want to change out with forged ones. If you use a different head you'll more than likely have to change them anyway to get your compression ratio right.
Brent
serious is offline   Reply With Quote
Old 09-10-2003, 01:05 AM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
My plan was to use ver7 sti heads.
Old 09-10-2003, 12:14 PM   #4
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Only problem with the V7 heads is the variable valve timing. You would have to run the stock ecu or find a aftermarket ecu that has the proper software to make them work.
Guys in OZ are using early close deck blocks and V6 heads. Apparently it has better flowing ports and improved combustion chambers. Not sure about the cams though. I still think V3 cams are the best.
Ver.III is offline   Reply With Quote
Old 09-10-2003, 12:46 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Ya... I realize what a wiring mess that will be.
From what I know US wrx heads are v6 castings. The problem with using them is the low CR they will give you right?
Old 09-11-2003, 05:06 PM   #6
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
so does any body know what sort of CR you would get with WRX heads on a ej22t using the stock pistons ?, Im thinking about doing this swap too, I will probably get forged pistons and connecting rods too. but the more info the better
oh ya are the WRX heads the ones with variable valve timing ?
thanks
4wheelflyer is offline   Reply With Quote
Old 09-11-2003, 05:32 PM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
Jdm wrx heads have avcs and so does the us sti but the wrx does not... but you would have to run a the ecu for that head which would be the wiring mess I was talking about.
Wrx heads would not be an ideal setup with the small ports and short deration low lift cams. You could get a port job and live with the cams... just dont bother with regrounds or welded cams. Rs heads flow better then wrx heads but I would never pick SOHC over DOHCs
I dont remember but its around here somewhere use the search theres a chart with a bunch of different setups and I know its been talked about just dont remember where.
Old 09-11-2003, 11:09 PM   #8
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
thanks , I just went down and talked with my mechanic and he said the WRX heads would not work very well ,so yes you where very right about that, but I was trying to avoid whole variable valve timing thing.
I think I will just get original ej22t heads ported.
overall which do you think will be better, RS heads or ej22t heads
for a stage 4 set up ?
thanks ......4WF
Old 09-12-2003, 04:16 AM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Well I dont know how much better the rs SOHC heads flow vs the legacys SOHC. But I wouldnt bother porting the legacys. You would be better off useing wrx heads and porting thoes... Or you could use jdm sti heads and not hook up the avcs. So many choices so little time.
Old 09-12-2003, 11:58 AM   #10
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Why not use the DOHC RS heads? From what I've heard they are the best of all 2.5 RS heads on a ej22t.
Compressed is offline   Reply With Quote
Old 09-12-2003, 12:08 PM   #11
BlackWagon
Member#: 9168
1994 power of k
where did you pick the motor up at?
BlackWagon is offline   Reply With Quote
Old 09-12-2003, 12:10 PM   #12
BlackWagon
Member#: 9168
1994 power of k
also does the wrx tranny bolt upto the ej22t block... vice versa... gears insterchangeable?
Old 09-12-2003, 12:16 PM   #13
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Exclamation
I believe the DOHC head will result in even lower CR compared to the SOHC head on a EJ22T (SOHC head gives 7.7:1)
kgb is offline   Reply With Quote
Old 09-12-2003, 12:29 PM   #14
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
The CR with the SOHC vs. DOHC RS heads is a function of the headgasket. The DOHC HG is a bit thicker and will drop the CR more. It is possible to use DOHC heads with a SOHC hg though to stay at 7.7:1.
Old 09-12-2003, 03:09 PM   #15
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
thanks all ,ya I plan on running a fair amount of boost so a 7.7:1 would be good. as for where im getting the motor my mechanic (he builds rally cars) can pretty well get any jdm or us/cadm motor ,its just a matter of cash. I was told the ej22t will bolt up to my 4eat (2.2L)tranny no prob ,it will have to be beefed up though, black wagon ,it may fit the WRX tranny ,I will ask him for ya
My question for the day is , when people say the engine has been ringed , are they meaning new piston rings or some sort of ring that goes between the block and the head for a stronger seal ?
thanks...4WF
Old 09-14-2003, 04:50 PM   #16
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
anyone know ?
Old 09-14-2003, 10:25 PM   #17
totoherbs
Member#: 7321
.... 122 IggPoints
From what I read on here the RS SOHCs flow better then RS DOHC, and wrx DOHC ...
Old 09-15-2003, 10:40 AM   #18
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
That might be true, I'm not sure. I have heard that the DOHC cams flow better, and have a much better top end, that is why I've heard them reccomended.
Old 09-15-2003, 02:27 PM   #19
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
more rpms with DOHC, safely
Scoobyslack1 is offline   Reply With Quote
Old 09-15-2003, 02:49 PM   #20
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Exclamation
I'm not sure about more RPMs with the DOHC - the design for SOHC head has changed enough that you could roughly go the same RPM with either one, not to mention you can get more lift with the SOHC heads.
Old 02-17-2004, 06:10 PM   #21
Teh Legacy
Member#: 9853
to keep your mouth
shut.
sooo...i'm thinking about doing the EJ22T block and the EJ25 DOHC heads with some sort of aftermarket cams...probably COBB stg 1 or if I end up running seriously high boost then Stg 3. Any ideas?
Old 02-17-2004, 06:21 PM   #22
serious
Member#: 22879
Yeah, get the 2.5 sti block instead.
Brent
Old 02-17-2004, 06:55 PM   #23
totoherbs
Member#: 7321
.... 122 IggPoints
Brent
Might save you some money, but the 2.2 is still a better block for high boost. I wouldnt use cobb cams, rewelds are a no-no.
Old 02-17-2004, 07:47 PM   #24
Teh Legacy
Member#: 9853
to keep your mouth
shut.
how much boost can I run to the 2.5 STi? How much can I pick one up for? What kind of head would I use? I dont want it to be a wiring nightmare, so the STi heads would be a problem. Thanks!
Old 02-17-2004, 08:03 PM   #25
totoherbs
Member#: 7321
.... 122 IggPoints
eek... um... lot of questions, most of them have been answered in other threads.
http://forums.nasioc.com/forums/show...hreadid=495863
This thread should get you started on your search....
Questions like how much boost is hard to answer... it depends on whos tuning, what turbo, 1000 other things. They go for $13xx, RS heads will work. There are a lot of threads with the info you are looking for.
Best Motor swap for a 98 Impreza Wagon JasonBlessed Newbies & FAQs 17 10-26-2009 09:45 AM
Best first mods for a Ver. 8 EJ207? prokaw875 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-12-2009 09:51 AM
ARP head studs for ej22t? nottofast Built Motor Discussion 8 05-27-2009 10:40 PM
What is the best WRX swap for my 00RS? Rallly2000 Subaru Conversions 12 10-11-2008 02:25 AM
Check these heads out for ej22t RobK0000 Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-22-2006 07:39 PM
