Old 09-09-2003, 12:56 PM   #1
STinger
Member#: 19410
'16 STI ISM
'95 LWRX Stage Rally Red
Default EJ18 timing belt questions
I'm going to do the timing belt on my EJ18 ('95 Impreza AWD). Looking at the instructions off the web at http://www.uniquemotorsports.com/sub...iming_belt.htm, it says to remove the cam sprockets, rear belt covers and tensioner bracket. Right after that, it says to install the belt covers, tensioner bracket, and cam sprockets.
Given this, is there a reason to uninstall these bits, then turn around and reinstall them again (though in a slightly different order)?
Can I compress the tensioner by hand, or do I need to get to a vise?
Finally, do I need to remove these bits to replace the water pump? It's leaking like an old boat.
Thanks,
Martin
STinger is offline   Reply With Quote
Old 09-09-2003, 09:11 PM   #2
imposter
Member#: 10642
95 Impreza EJ22T
1. Removing the cam sprokets and everything else beyond actually removing the belt is unnecessary.
2. No, you will need a vise. Dont compress it too quickly or you could ruin it.
3. Just the sprocket and rear cover on the left side.
-Jim
imposter is offline   Reply With Quote
Old 09-10-2003, 02:15 AM   #3
STinger
Member#: 19410
'16 STI ISM
Perfect. Thanks!
usdm ej20 Timing belt question PumpsGOTAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-20-2004 06:58 PM
Timing belt questions ducktapeguy Southern California Impreza Club Forum -- SCIC 3 03-19-2004 02:07 AM
Timing belt question paulatwork New England Impreza Club Forum -- NESIC 2 11-18-2002 10:20 PM
Timing belt question Legacy Service & Maintenance 1 12-30-2001 07:52 PM
WRX Sti Timing belt question Yellow_turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-12-2001 12:47 PM
