Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 09-09-2003, 02:40 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default how long is the flex clutch cable?
hey- just wondering if somone could give me an approx length of the flex clutch tube cable on a hydrolic clutch. i want to make one out of earls
thanks
h
supermoose is offline   Reply With Quote
Old 09-09-2003, 03:52 PM   #2
RedBrighton96
Member#: 1246
2007 WRX TR
6" for the WRX i believe, and 10" for the RS
and as a side note, the lines are not interchangable, the end that connects to the slave cyl is a different size on both
Rob
RedBrighton96 is offline   Reply With Quote
Old 09-09-2003, 04:00 PM   #3
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
it's maybe 12-16 inches? I bought mine from Bonaco Performance lines of Upland, CA. They don't have a website though. It cost about $30, and installation was a snap.
-scott-
For reference, those are 8.5x11 letter-size sheets of paper under the clutch lines.
scotty305 is offline   Reply With Quote
Old 09-09-2003, 04:21 PM   #4
supermoose
Member#: 9093
swap starr
Default line
what size line will i need for my setup then? im putting a JDM 94 STI trans in my 93 impreza L, using JDM clutch MC and slave cylinder
also, does anyone know the fittings size?
h
Old 09-09-2003, 04:30 PM   #5
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Dude, just bring the original line to your local hose shop, and they will make you one that will work. That's what I did, it was really easy and took the shop about 10 minutes, they made the line while I waited. If you're using a japanese transmission, your line will be different than my line, I'm pretty sure the JDM tranny uses a pull-type clutch slave cylinder. USDM non-turbo uses push-type clutch slave cylinder.
Look it up in your phone book, or check http://www.streetperformance.com/?catid=183 , it's a big directory of car stuff, hopefully there's someone near you.
good luck,
-scott-
Old 09-10-2003, 12:46 PM   #6
supermoose
Member#: 9093
swap starr
Default hmm
local hose shop then? problem is htat i dont hvae the original hose, i hvae the cut endof one, and the metal fitting on the MC for it to go on
h
Old 09-10-2003, 04:30 PM   #7
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
... then bring them what you've got, if you're missing one end, bring them the piece that you need it to connect to. A decent shop should either be able to work something out, or refer you to someone who can.
Sorry to be rude, but is that such a difficult concept that you didn't think of it? I hope you're up to the challenge of a motor swap, I've heard wiring's a pain, and you're not going to get nearly this much help with wiring because most people aren't as familiar with it...
good luck,
-scott-
Old 09-11-2003, 04:35 AM   #8
supermoose
Member#: 9093
swap starr
Default word.
hey- i was just wondering if anyone knew the #'s for the fittings so i could order some earls online, ive done quite a bit of converting (putting a JDM 4.11 box in a FWD L this weekend) so id say im pretty decent on thinking on my feet. i think ive located a local shop with steel line bits, so ill be posting the specs and results.
oh also, in a pinch, a stock rubber brake line has the same fitting sizes on both ends
h
any one know how long is the adjustable screw at the back on the HKS SSQV BOV starBug Engine Management & Tuning 3 06-04-2004 11:57 PM
any one know how long is the adjustable screw at the back on the HKS SSQV BOV starBug General Community 1 06-02-2004 08:14 PM
how long is the flex clutch cable? supermoose Transmission (AT/MT) & Driveline 2 09-10-2003 12:46 PM
How long is the WRX clutch under warrenty? Gypsum2 Transmission (AT/MT) & Driveline 7 10-09-2001 08:24 PM
('93-'01) How long is the WRX clutch under warrenty Gypsum2 Impreza Forum 5 09-11-2001 01:48 AM
