Old 09-09-2003, 03:39 PM   #1
MidNiteImpreza
Member#: 42597
2003 Subaru WRX
black
Default valves clicking louder?
hey whats up guys, remember the first time YOU got ur WRX?, now i know the boxer motor makes alot of noise, but it seems like my valve clicking noise has gotten louder since i bought it, oil is fine, everything should be ok, i only have a HKS down pipe and greddy intake in mine, i dunno maybe its just me, just wanted to see other peoples opinion or if any one else experienced the same
MidNiteImpreza is offline   Reply With Quote
Old 09-09-2003, 05:17 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
When have you changed your oil?
Old 09-09-2003, 06:01 PM   #3
MidNiteImpreza
Member#: 42597
2003 Subaru WRX
black
dont worry about the oil , i said it was fine, i change my oil every 2500 miles mobil 1 Full synthetic 5w30
Old 09-09-2003, 06:25 PM   #4
Ken
Member#: 34
2005 WRX STi
World Rally Blue
It will be louder if your timing belt tensioner is shot or loose, but I doubt that's your problem.
Ken is offline   Reply With Quote
Old 09-09-2003, 06:31 PM   #5
MidNiteImpreza
Member#: 42597
2003 Subaru WRX
black
neither do i as matter of fact i dont even look at this as a problem guys, lol im looking to see if any one has experienced the same? not to point out possible mechanical faults or what not, just reply if u have experienced a SLIGHT increase in noise???? is it becaus the motor miiiiight be broken in ? i dunno
Old 09-09-2003, 07:00 PM   #6
Ken
Member#: 34
2005 WRX STi
World Rally Blue
I know it gets louder as you put more miles on our oil. After a fresh change it's quite quiet. After warm up it's obviously more quiet than when cold. Or one straight friggin' cold days it's sometimes a hideous sound.
Old 09-09-2003, 07:50 PM   #7
MidNiteImpreza
Member#: 42597
2003 Subaru WRX
black
Thumbs up
i c , cool man thanks for the info
Old 09-09-2003, 09:23 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
Did you use a different weight of oil?
Old 09-09-2003, 10:29 PM   #9
WRX02WRB
Member#: 36240
2015 STi
i think mine has gotten louder with more miles ....i was stressin about it at first ..then i just said screw it if it breaks it breaks ...i might as well enjoy it and not stress
WRX02WRB is offline   Reply With Quote
Old 09-09-2003, 11:39 PM   #10
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default tensioner
It's probably the tensioner. Some clicking is normal, though.
vvk is offline   Reply With Quote
Old 09-10-2003, 12:00 AM   #11
MidNiteImpreza
Member#: 42597
2003 Subaru WRX
black
ok ive got a little over four grand on my mileage, you guys really think its a tensioner?? and yes this ones to (((ciper))) i tried mobil 1 10w30 because i did research and alot of peopler where using it and it worked great, esp for hotter climates because im moving to Arizona soon, but then i switched back to 5w because... well ... my friends running 280 to the wheels on he's wrx and hes been using 5w30 and its fine, and i dont think it would screw anything up with that transfer because..... Full synthetics viscosity are diff to regular oil, its basically insense thinner so there for even if ur using a 10w30 full synth in ur 5w30motor it shouldnt mess it up because the oil is still able to flow through its passages. AMEN!
P.s i know on higher horsepower / modified vehicles, its good to use a thicker oil because of the build up of friction and impact do to the heavy modifications ( and yes i wrote this high so most likely.. i must be pulling things outa my head )
Old 09-10-2003, 09:11 AM   #12
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Did you buy the car new? I see your running fully synthetic and only have 4,000 miles on your car. When did you switch to full synthetic? I know this is arguable, but I wouldn't switch to full synthetic until between 5-10,000 miles. Maybe your valve chatter has something to do with the engine being broken in improperly. But, like everyone else said, it's probably the tensioner.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 09-10-2003, 09:20 AM   #13
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
His using synthetic oil has absolutely nothing to do with valve noise. Nor can anyone produce more than heresay evidence that switching to synthetic prior to XXXX miles is a bad thing. The reason being, there's no reason to wait.
Take a good look at your manual... it says quite clearly that you can use synthetic, provided it meets all the requirements set out (i.e. service specs and weight).
For every "my buddy told me that synthetic is bad if you blah blah blah", I can produce actual chemical analysis reports that make it rather obvious that the only difference between synthetic and conventional oils is that synthetic is more resistant to breakdown. Ergo, there's nothing about synthetic that will not allow your engine to break in just like it would on conventional oil.
I've run synthetic since 1700 miles. I've got over 8000 on the car now. It runs the same as always.
heffergm is offline   Reply With Quote
Old 09-10-2003, 09:53 AM   #14
vile
Member#: 32371
'02 t-rex wagon
platinum
before this turns into a "battle of oil thread"......just wanted to say.....i've began to notice my valves are making a little more noise then usual...i'm at 43k mi.....all my maintance has been kept up perfectly....oil changed at the same interval, all filters swap, u name it, i've probably done it already(in terms of maintance)s
i've actually just noticed it the other day...didn't think too much of it though
vile is offline   Reply With Quote
Old 09-10-2003, 05:31 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
You guys suck. No more talk of synthetic or conventional please.
MidNiteImpreza: Try the 10w-30 and wait 100 miles or so after filling, see if the noise changes.
You dont need to explain oil to me. It also doesnt matter what horsepower your friend is running. I know plenty of people running huge power dont filter the air, why dont you do the same?
Old 09-10-2003, 07:43 PM   #16
MidNiteImpreza
Member#: 42597
2003 Subaru WRX
black
wow dude, did you sleep with ur legs open last night? because it seems like something crawled right up yer ass
Old 09-10-2003, 10:43 PM   #17
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Everyone has to learn somewhere and not everyone has time to read and search every post on NASIOC. Ciper is a good guy, he has helped me out with my questions a couple of times. But yes, that did seem kind of rude. Not everyone is equally knowledgeable.
-Charles-
Old 09-10-2003, 11:37 PM   #18
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Correct me if Im wrong but......I dont think we have hydraulic lifters, and, if we do they are meant to be "shimmed" which would lead me to believe it is a mainteance sort of thing.
Im making this assumption after quickly referencing the service manual, there appears to be a procedure for checking valve clearances, and replacing the stock shim with a thicker one.
I remember drastically improving the sound of my 84 bmw 318 after using a feeler gauge to tighten up the valve to rocker arm clearance. Its not quite as easy on a boxer motor.
Is this something that will probably need to be serviced but subaru conveniently leaves out of the maintenance schedule?
Is this the sound that the old Subarus I see/hear are making? Or is that a timing belt tensioner thing?
santofontana is offline   Reply With Quote
Old 09-11-2003, 02:09 PM   #19
ciper
Member#: 15543
90BJ Legacy LS ABS
You guys are too sensitive. I wasnt being rude in my post, just blunt.
Whatever, no help for you then.
Has anybody modified the stock blow off valve to be louder? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-13-2012 12:28 AM
Valves Clicking ? braemaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-29-2006 10:44 PM
Blow-off Valve - Want to change OEM to a louder unit DubyaRx900 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-28-2005 03:16 PM
even louder clicking sound? 1stonscene North West Impreza Club Forum -- NWIC 5 12-22-2003 06:57 PM
Make the factory blowoff valve louder? orvacian Newbies & FAQs 10 04-16-2002 08:57 PM
