Old 09-09-2003, 03:40 PM   #1
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
Default Gutted CAT
I have a 2000 RS with Borla headers and a Tanabe super racing medalion cat back would it help or hurt to gut the cat/cats and has anyone done this
pistoffjstr is offline   Reply With Quote
Old 09-09-2003, 06:15 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
1. Why would you think it would help?
2. Don't you care about the air you breathe?
Julian is offline   Reply With Quote
Old 09-09-2003, 06:23 PM   #3
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Why do you ask such stupid questions instead of answering his question?
Yes, of course removing the cat would help free up more power. Currently you have a bottleneck of airflow at the cat and removing it would free up a little more power.
JewPac42 is offline   Reply With Quote
Old 09-09-2003, 08:00 PM   #4
Zen
Member#: 12656
You could always go to a muffler shop or performance shop and get a custom catless midpipe made for cheap.
Zen is offline   Reply With Quote
Old 09-09-2003, 08:33 PM   #5
obyone
Member#: 16523
You get more power this way because the piping is also a bottleneck in the cat section.
obyone is offline   Reply With Quote
Old 09-09-2003, 09:51 PM   #6
pistoffjstr
Member#: 29283
Red
thought about that too then i would have to get the end fittings so i could bolt it right up maybe i will just do that ....looking at my cat it might cause wierd airflow instead of smooth if i just gutted it
Old 09-10-2003, 11:30 AM   #7
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Bingo! Gutting the cat on any car, and especially our cars with the pipe routing will lead to significantly more turbulence in the exhaust system. It would definitely be better to get a test pipe made up, better for power and you can keep your cat section for those "just in case" times.
Compressed is offline   Reply With Quote
Old 09-10-2003, 05:39 PM   #8
Julian
Member#: 1182
MY00 RS
BRP
JewPac, who let you out of your cage?
In any case, why do you think the cross section of the cat is so much larger than the inlet pipe diameter? Do the math.
If you think gutting your cat will gain you any noticable horsepower in your Subaru, think again. Or show me the dyno sheet.
Old 09-10-2003, 06:52 PM   #9
Supraru
Member#: 23313
99' 2.5Rs
black
Julian, you could have been a little more helpful at first. Honestly who answers a question with a question. You definatly came off as a wise guy. Maybe you are, I don't know you. If he knew the answer he wouldn't be asking it. I'm sure someone talking as if they know it all dosn't help, just a simple answer would probably help him out.
If I were you I would get a pipe made or just buy a high flow cat. You may find it hard to get a shop to make you a pipe since you would be removing your cat. If you get pulled over and you rat them out they will get an insanly huge fine. They basically say they will forget the ticket if you tell them who took it off. If your good friends with the person who did it then you obviously won't rat them out but normal shops won't take a great chance on someone they don't know.
Supraru is offline   Reply With Quote
Old 09-10-2003, 09:11 PM   #10
pistoffjstr
Member#: 29283
Red
i was thinking about just going to a junkyard and getting a small cat and ramming a strait pipe through it and then getting the proper fittings welded to it and put that on ....that way it at least looks like there is a cat
Old 09-10-2003, 09:17 PM   #11
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
Would it be important for it to look like there was a cat? Would a cop really check to see if you had one? And would he know where to find it? It seems to me having a replacement mid-pipe made with out the cat might be a good idea, then you can take the stock one off and put it back on for smog time.
mprezuhguy is offline   Reply With Quote
Old 09-10-2003, 10:15 PM   #12
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
That it does, it also sounds really odd too. I ended up getting a high flow cat and pipe made up. Ran me about 140 for cat and pipe.
As for not adding performance I'll throw up the BS flag. People that have rode in my car numerous times noticed the difference. 4th gear pulls a good amount harder. As for dyno sheets pay for it and I'll gladly get you some
EvasionOfTruth is offline   Reply With Quote
Gutted Cat./hi Flow Cat/race Pipe??? partingwrex88 Private 'Wanted' Classifieds 3 11-28-2008 07:40 PM
Gutted cats or new up/down pipe? Nordstone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-02-2004 02:39 PM
Any ideas about gutted cat? (getting misfire code) Andursun0013 Normally Aspirated Powertrain 2 06-10-2003 09:45 PM
Gutted Cat??? I3eXa Newbies & FAQs 6 04-29-2003 11:39 AM
gutting cats streetspanker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 04-21-2003 10:57 AM
