Mid Atlantic Impreza Club
Old 09-09-2003, 10:02 PM   #1
DCAPOSSELA
Member#: 2361
2000 2.5 RS Sedan
Sedona Red Pearl
Default Just installed Stromung Cat
I just instaled my new cat and I have a majior clunking noise in the front end when I take my foot off the gas in lower gears. Especially 1st thru 3rd. I have a feeling that it is either motor or trans mounts.
Does this sound like I am in the right direction, and if so does anybody have an idea where I can get some from for a decent price?
The car sounds great with the dual tip and cat, but I don't want to be too hard on it until I replace the mounts.
DCAPOSSELA is offline   Reply With Quote
Old 09-10-2003, 12:27 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
jack up the corner of the car that the sound is coming from and check to see if your lugs are tightened the whole way.
Brent
scoobyimprza is offline   Reply With Quote
Old 09-10-2003, 08:40 AM   #3
GQ
Member#: 4830
12 DucatiSF/Abarth
Red/Nero
My car did the exact same thing after I installed the Stromung Cat. I thought that it was the engine banging around in the mounts too.
I have to say, Gesh the exhaust is LOUD now.
Rob
GQ is offline   Reply With Quote
Old 09-10-2003, 10:58 AM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Try a straight pipe with Borla Headers and Stromung Single tip
Anyway this noise only happened after you did the cat install?
Then it has to relate to the cat. Its not motor or tranny mounts. It may be the cat contacting the tranny mount.
A good starting point is to make sure the bolt in cat hanger is tightened down as much as possible without damaging it. Also if the cat has a flex joint the clunk could be coming from that. If its a ribbed flex joint then the ribs will heat up and become stiff and solid. When you let off the gas and the motor shifts, the flex pipe in the cat is forced to shift also. When the ribs shift it probably makes a good click or clunk noise.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 09-10-2003, 11:55 AM   #5
DCAPOSSELA
Member#: 2361
2000 2.5 RS Sedan
Sedona Red Pearl
The reason I thought it was the trans mount is because one time I felt it I happened to be looking down at shift lever, and I watched it physically move.
BTW my CEL came back on this morning. I guess I am going to have to order the kit to splice it into my O2 Sensor. Does anybody know how many I will need to order? I know that there are 2 O2 Sensors, but don't know if it is needed on one or both sensors.
Old 09-10-2003, 12:30 PM   #6
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
You only need to order 1, just splices into the rear O2 sensor. The front is still used by your ecu, for other functions than just emissions.
Buster
Site: http://www.ponyexpressperformance.com/WRXMILTest1.html
EvasionOfTruth is offline   Reply With Quote
Short rant: Tried installing Stromung cat pipe. Yeah.. that went well... Siper2 Normally Aspirated Powertrain 42 04-05-2006 10:10 AM
Help installing MIL (CEL eliminator) for Stromung cat. pipe Siper2 Normally Aspirated Powertrain 12 03-07-2006 10:03 AM
Just installed Stromung TB (w/ Accessport) lupohki Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 07-11-2004 12:00 AM
Just installed my Stromung over lunch! Matt Monson Bay Area Impreza Club Forum -- BAIC 20 09-12-2000 12:51 AM
