Old 09-10-2003, 02:23 AM   #1
hitman912
Member#: 38811
2002 WRX Sedan
Platinum Silver
Default check engine light
i dont know where else to post this........but my check engine light came on so i set up an appointment for friday to get my 02 wrx checked out. i have after market exhaust and intake so will they deny my warranty??? please dont yell at me if this shouldnt be here. thanks.
dave
hitman912 is offline   Reply With Quote
Old 09-10-2003, 02:25 AM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
They can deny you warranty if the CEL is related to whatever part of the car you have mods on. Exhaust should generally be ok. but say you have a blown MAF. it could be cause of the intake.
Ken is offline   Reply With Quote
Old 09-10-2003, 08:39 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There are many potential causes for the CEL to come on, but before heading to the dealer check the obvious first. Did you get gas recently? Look at your gas cap and be sure it is tightened fully past where it clicks, if it isn't a CEL will result (there is a warning right on the cap).
Old 09-10-2003, 10:51 AM   #4
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Take it to an Autozone and get the code pulled for free, so you can tell them exactly what it is. You may be able to avoid a hefty "diagnosis" charge that some (most?) dealers use to cover the extraordinary time and effort it takes to plug their monitor into your OBDII port.
Zola is offline   Reply With Quote
Old 09-10-2003, 07:27 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Autozone in CA is no longer pulling codes for free, some kind of legal issue.
If you still want to get it checked before you go to the dealer post in your local forum to see if someone local to you has a scanner and can read the code.
Old 09-10-2003, 08:57 PM   #6
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Wow...that's really a bummer. I would be so pissed!
Old 09-10-2003, 10:38 PM   #7
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Probably a misfire..... such as P0304.... I invested in a OBD2 code reader and it's always busy at the local subaru meets....
On the WRX's, I pull lots of misfires....
Robin
Robin2 is offline   Reply With Quote
Old 09-11-2003, 01:48 AM   #8
hitman912
Member#: 38811
2002 WRX Sedan
Platinum Silver
thanks for the info guys. i appreciate it very much.
Old 09-12-2003, 09:05 PM   #9
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
How long have you had the exhaust and are you catless? A 2k or a 2.2k ohm resistor (can't remember which one exactly) can be inserted into the O2 sensor wiring harness... The one coming off the downpipe. Just bend it into a U shape. Try both.
As far as your MAF being blown... your car will not run if this was the problem.
dj_noose is offline   Reply With Quote
Old 09-12-2003, 09:10 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The 2.2K ohm resistor is used to replace the EGT sensor in the uppipe. It has nothing to do with a CEL fix for the rear 02/catless exhaust.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 04:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 01:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 10:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 03:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 08:50 AM
