Old 09-10-2003, 05:27 AM   #1
AussieForesterMY2003
Member#: 43215
Post Idle adjustmet
Hi Folks,was just wondering if anyone can tell me how to adjust the idle on my wifes Forester,it is a MY2003 manual X model.Thanks.
AussieForesterMY2003 is offline   Reply With Quote
Old 09-10-2003, 07:37 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Aussie Forester- uh, are you in Australia, or where are you?
The idle is controlled by the ECU and isn't readily adjustable. There is a stop screw on the throttle lever but you can't just turn that because the ECU will compensate for the change. If the engine doesn't idle properly have it checked by a dealer.
The above is true for US models and should be the same for others as well.
Old 09-13-2003, 04:34 AM   #3
Member#: 43215
Hi Mulder,I'm in Sydney Aus,thanks for the info,I will have to get it looked at next service.
Idle air whatever control, weird idle page02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-31-2007 10:33 PM
Low idle while coming to a stop, ruff idle and plug install mishap??? Clzay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-27-2006 09:03 AM
weird idle issue...not average idle stuff slingshot Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-25-2006 04:24 PM
Erratic idle @..... idle. SilverBullet2.5RS Normally Aspirated Powertrain 7 06-24-2006 03:07 AM
My idle speed is inconsistent at Idle, is this normal? LisaPhish Legacy Forum 17 07-15-2003 02:01 AM
