Old 09-10-2003, 02:01 PM   #1
AaronWRX
Member#: 7194
2011 997.2 Turbo
Default Parking break light... gets stuck.
Hello,
My parking break light will come on and turn off. I think something is loose because the light will come on gover over rough roads or when I accelerate hard.
Any idea? Do you think its a sensor or just not adjusted properly?
AaronWRX is offline   Reply With Quote
Old 09-10-2003, 02:20 PM   #2
tdxflex
Member#: 13634
Check your brake fluid reservoir. The light also comes on when you're low on fluid.
tdxflex is offline   Reply With Quote
Old 09-10-2003, 02:38 PM   #3
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default brake pads
Like tdxflex said, check your brake fluid level. A low level is an indication of worn pads, so check those too.
vvk is offline   Reply With Quote
Old 09-10-2003, 03:13 PM   #4
AaronWRX
Member#: 7194
2011 997.2 Turbo
Good advice! Thanks!
Old 09-11-2003, 01:36 PM   #5
Austin
Member#: 7089
2016 STi
If you find you're not low on fluid, the parking brake switch is directly under the parking brake handle - it's a pin switch.
Austin is offline   Reply With Quote
07 forester brake pedal getting stuck to the floor 04subywrxsti Brakes, Steering & Suspension 0 05-22-2009 07:29 AM
Anyones Parking Brake light f00ked? Soontobe Texas Impreza Club Forum -- TXIC 4 01-27-2004 06:57 PM
Parking Brake light staying on??? NYWRXTASY Brakes, Steering & Suspension 8 04-09-2003 08:57 PM
Parking Brake light keeps going on and off? SpamMansXe Mid Atlantic Impreza Club -- MAIC 16 04-01-2003 12:29 PM
parking brake light comes on WARIAT12 Service & Maintenance 5 09-12-2002 02:01 AM
