Welcome to the North American Subaru Impreza Owners Club Thursday August 28, 2014
Old 09-10-2003, 05:23 PM   #1
poison
Member#: 37678
Default Any opinions on WaterWetter?
poison is online now   Reply With Quote
Old 09-11-2003, 08:32 AM   #2
MrHorspwer
Member#: 4063
My dad has a fairly well modified 1970 El Camino. It runs hot in traffic. He's running straight water and Water Wetter right now (will be replaced with antifreeze in the winter as Water Wetter doesn't lower the freezing point) and the car has yet to pass 220 degrees F... running a 50/50 mix would send it well above that, forcing him to shut the car down.
The stuff works... how well it works with an antifreeze mix is another question. Without a mechanical temp gauge, I don't think you'll see any difference... I didn't. I did dump a half bottle in the Subaru with no preceviable change in the gauge readings. I don't think the I/P temp gauge is sensitive enough to register a change even if there was one.
I believe Redline has a great product line and I do know the Water Wetter works great in a straight water mix. Redline says it makes a difference with antifreeze, though not as large as with straight water. I guess you can take that with a grain of salt.
MrHorspwer is offline   Reply With Quote
Old 09-11-2003, 02:14 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The point of water wetter is not to reduce overall temperature. With a cooling system that works properly the water wetter should show no difference in temperature no matter what gauge you use.
The water wetter is to stabilize temperature, to make the water more conductive to heat. Meaning hot spots that currently exist in your car will cool faster.
My feeling is that you should try to run the least amount of antifreeze in order to prevent corrosion. Anti freeze holds less heat than plain water and expands 1.2 times as much.
I run about 15-20% coolant, a bottle of water wetter and distilled water.
Old 09-11-2003, 02:18 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
water wetter is THE STUFF...
i use it in the rally car... it's the best and it works...!!
jamie
www.subiegal.com
Old 09-11-2003, 03:18 PM   #5
rilles
Member#: 14332
2003 RS
blue
I used it in a '89 Mustang, 20% anti-freeze - worked great, didn't make things cooler - but it kept the temps down.
rilles is offline   Reply With Quote
Old 09-11-2003, 03:45 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
Old 09-13-2003, 08:32 PM   #7
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I put it in my 02 WRX which I drive 99% at the track. I could swear that after I put it in my temp gauge ran a bit cooler then normal.
I'm happy with it.
-Scott
cky211 is offline   Reply With Quote
Old 09-14-2003, 01:34 PM   #8
cvalle-sd
Member#: 420
2001 Cr-V
Love It - I run ~20-25% coolant, WW, and distilled H20.
cvalle-sd is offline   Reply With Quote
Any opinions on Ultimate speakers? tsbarro Car Audio, Video & Security 2 07-10-2002 10:54 AM
Any Opinions on STI replica Strut Tower Braces SubaruEJ25 Brakes, Steering & Suspension 3 01-23-2002 01:17 PM
APEX Coilovers: Anyone have any opinions on them? Bob O Brakes, Steering & Suspension 20 05-23-2001 10:10 AM
Any opinions on Ronal wheels? '83 DL WGN Brakes, Steering & Suspension 6 10-29-2000 01:11 AM
Any opinion on sub?? sti2_5rs Car Audio, Video & Security 15 06-18-2000 01:11 PM
