Old 09-11-2003, 01:23 AM   #1
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
Default KYB AGX or GR2?
I know the AGX doesn't apply for our Legacies but it does for the RS's and have heard that these struts would work for the BDs. For you guys that have this on your car was there any fitment issues? And whats the part # for these struts.
If i can't the AGX i was thinking of getting the GR2. Has anybody tried these struts? How well do they handle and the ride (comfy, rough).
Thanks, V :smile:
VOLTIS5 is offline   Reply With Quote
Old 09-11-2003, 10:09 AM   #2
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
If you don't plan on making a bunch of shock setting adjustments, get the GR-2's.
Opie is offline   Reply With Quote
Old 09-11-2003, 10:32 AM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Go with the GR-2's. They are set to the most commonly used AGX setting 2f/4r. I have the AGX and wish I had gone with the GR-2 that is specific for our cars.
maciek is offline   Reply With Quote
Old 09-11-2003, 11:00 AM   #4
VOLTIS5
Member#: 2353
98' LegOver GT
would i still be able to use my stock spring if i go with the GR2 or AGX? And if i need to change it, which spring gives the least drop?
I'm thinking of going for the GR2 since its a lot cheaper ($76f/$68r).
Old 09-11-2003, 12:25 PM   #5
legacy2003
Member#: 38338
2003 Outback Sdn H6
i asked this same question about a month ago or so because i have impreza agx shocks on my bd... just not on the car yet. there should be no fitment issues, the perch will sit a little higher in the front than the rear by about 1/2 inch or so. try doing a search about it type in struts legacy and you should see it with me as the thread starter.
-mike
legacy2003 is offline   Reply With Quote
Old 09-11-2003, 12:32 PM   #6
legacy2003
Member#: 38338
2003 Outback Sdn H6
actually i got bored so i did the dirty work for you:
http://forums.nasioc.com/forums/show...ght=legacy2003
that was my thread from a little while back, hope this helps.
-mike
Old 09-11-2003, 01:33 PM   #7
SUBE555
Member#: 24043
2005 Legacy GT Sedan
GR2's work great on mine!
SUBE555 is offline   Reply With Quote
Old 09-11-2003, 01:58 PM   #8
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
for all your KYB Struts Needs.. check out http://www.kybstruts.com
and .. nope ain't my site but they seem to have everything KYB
oh.. I did order me set of GR-2's $250 + s&h for all 4
NiTRoN is offline   Reply With Quote
Old 09-11-2003, 02:12 PM   #9
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
where are they for that price? that is cheap. tirerack.com?
subiekid is offline   Reply With Quote
Old 09-11-2003, 02:17 PM   #10
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
both the GR-2 and AGX will work with your stock springs....but...I recommend to do the springs as well. You do not want to do all that labor twice, just get the springs.
As for the least drop....Whitelines.
I think you can get stock ride height or 1 inch drop.
Old 09-11-2003, 02:22 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Consider hardened top hats as well, the STI units specifically work great and can be had for about 200 all four corners.
Old 09-11-2003, 02:34 PM   #12
subiekid
Member#: 25516
if you get the gr2s then you dont have to worry about the bad gap from using the agxs ment for the rs.
Old 09-11-2003, 02:50 PM   #13
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
it's from www.kybstruts.com
click on GR2 link.. and you will see part# with prices..
you have to download the part locator from www.kyb.com here is direct link http://www.kyb.com/downloads/kyb_multiview.zip
Old 09-11-2003, 05:12 PM   #14
subiekid
Member#: 25516
where can you get sti top hats for that price? z1 said they would be 260 plus shipping. and i dont think he has any in.
Old 09-11-2003, 05:37 PM   #15
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
subiekid
try www.boxer4racing.com
Taughe has front for 140 and rear for 140..
that's 40 bucks more.. but he might have em in stock
Old 09-11-2003, 06:06 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
I actually got mine for LESS than 200 becuase I picked them up locally. Just find someone who has 93+ impreza mounts, they are very cheap.
With my car I had to get some spring seats as well, since my rear mounts are a single piece but otherwise they are great.
http://www.gruppe-s.com/Subaru/subsus.htm
200 for all 4 SHIPPED!
Thats the place I picked them up, they are local to me.
Old 09-11-2003, 07:26 PM   #17
subiekid
Member#: 25516
so the impreza ones fit the 90 to 99 legacy? that is cool. i knew it was something like that but had forgoten. now i am just gona get a pair of rear sti mounts and put on my syms rear strut bar, and then get a pair of pillow ball mounts for the front.
Old 09-11-2003, 08:36 PM   #18
ciper
Member#: 15543
90BJ Legacy LS ABS
They will fit.
Are your rear mounts two part?
Old 09-11-2003, 09:06 PM   #19
subiekid
Member#: 25516
i have no idea. i have never looked at them, and i dont have my hayens with me so i cant look.
Old 09-11-2003, 09:19 PM   #20
ciper
Member#: 15543
90BJ Legacy LS ABS
Worst case you will need to purchase the spring plate to match the mounts from the dealer. Still worth it though.
Old 09-12-2003, 12:30 AM   #21
VOLTIS5
Member#: 2353
98' LegOver GT
Does Eibach have an inch drop springs as well? i asked Dale at TeaguesAuto and he said that Eibach would have em (he doesn't carry Whitelines products anymore) but wasn't sure if it was actually an inch.
I'm am going to get springs as well when i order the struts but don't wanna drop it that low.
THANKS for helping me out guys!!! Its greatly APPRICIATED
Debate: KYB AGX or GR2 or KONISPORTS jd20jd Brakes, Steering & Suspension 3 01-26-2007 06:52 PM
Prodrive springs (Red vs. Blue) on AGX or Gr2 moogoob Brakes, Steering & Suspension 3 03-15-2006 07:29 AM
KYB AGX or KYB GR2 ? 99subi Brakes, Steering & Suspension 11 03-13-2005 03:46 PM
AGX or GR2? sha_zapple Legacy Forum 32 02-08-2005 07:57 PM
KYB AGX vs GR2 AGAIN rallysquirrel Brakes, Steering & Suspension 0 08-16-2002 07:16 PM
