Old 09-11-2003, 11:40 AM   #1
x12oyx316x
Member#: 14532
2002 rexakacorolla
Platinum Silver Metallic
Default want to put stock airbox back on
not too sure which forum this goes under but i'll just have to take my chances. . i have a cai on my 02 wrx and want to replace that with my stock airbox (too many horror stories about the MAF thing). . anyways. i seem to have lost every bolt/screw that basically holds down the stock intake and ram air scoop and would like to know what size these bolts are so i can go buy them. . thanks in advance
x12oyx316x is offline   Reply With Quote
Old 09-11-2003, 01:53 PM   #2
kenchan
Member#: 15106
you should go to your dealer's parts department with your
notepad and ask them to let you take a look at the parts book.
afterwards, go to Ace hardware and buy your metric bolts.
i found that homedepot only has a handful.
kenchan is offline   Reply With Quote
Old 09-11-2003, 02:22 PM   #3
tdxflex
Member#: 13634
Taking a guess here, but all of the 12mm bolts (talking about what socket you would use) seem to be m8 x 1.25 threading, all of the 14mm bolts m10 x 1.25. The ECU cover plate are 10mm bolts and the threading is m6 x 1.0.
I'm pretty sure the two front bolts to hold the ram scoop were smaller than all the others and are m6 x 1.0, and the rest are all m8 x 1.25. Don't have my car with me or else I could do some matching up with my thread chasers.
edit: actually I think the swaybar links don't follow this pattern, but all of the intake bolts still look like they're m8's.
tdxflex is offline   Reply With Quote
Old 09-11-2003, 03:43 PM   #4
x12oyx316x
Member#: 14532
2002 rexakacorolla
thanks for the help. . i'll just probably go to my nearest dealer and get the correct bolt sizes. . i think i have one of them. . but i'm not too sure. . ahh i'll just have to get my lazy a$$ up
Put stock airbox back on and threw a CEL JewPac42 Normally Aspirated Powertrain 2 08-11-2004 06:14 PM
whats the easiest way to put stock bov back on? generalwrx Newbies & FAQs 3 11-12-2003 05:21 PM
effects of putting stock muffler back on? makanouchi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-24-2002 11:25 AM
Need help putting stock airbox back on on 99 rs mcu81 Tri-State Area Forum 4 08-13-2001 09:55 PM
putting stock airbox back in... questions. alastair Tri-State Area Forum 16 03-24-2001 01:59 AM
