Old 09-11-2003, 10:22 PM   #1
SharP
Member#: 41705
1995 Legacy L Sedan
Baby Blue
Default CV boots broke
And now i have a decision to make 1 i can buy boots that i can put on myself without taking the axle or i can pay 250$ for a mechanic that will profesionally remore the broken ones and put a new ones in there .... can someone suggest me what to do and how important this is anyways .. coz maybe the self-put ones are okay for me (dont race the car 2 much and dont really go above 70) .. maybe its not a big deal ?
Thanks for your esponses
SharP is offline   Reply With Quote
Old 09-11-2003, 10:29 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you're referring to the "split" type boot kits that go on without removing the axle, I don't recommend it. These may be cheaper and easier in the short term but once the boot breaks and the car is driven that way for a while the grease leaks out and dirt gets in. If you don't remove the axles and clean and re-grease the joints before replacing the boots, the joints are almost guaranteed to fail later on (maybe not much later either). This type of repair is false economy, it's best to do it right the first time.
You may be able to get some remanufactured exchange axles for not much more than the boot repair would cost.
Old 09-11-2003, 11:13 PM   #3
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
I'd go for a new half shaft or remanafactured one also. I just replaced mine last week after it starting to fail a few months ago. There is nothing worse than hearing a clicking when you try to make sharp turns.
Mine was in the rear though so it was bearable
Buster
EvasionOfTruth is offline   Reply With Quote
Old 09-12-2003, 03:16 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
I had two outside boots go withing a week of each other last year, left then a week later right. I was at schoool at the time and needed them done ASAPcause i had a track even the coming weekend. It cost $140 each time. removed, cleaned, inspected, repacked with grease, new boots, and reinstalled. At the local dealership.
Hawk296 is offline   Reply With Quote
Changing CV boots, forgot how to put back CV joint bearing franke3c Transmission (AT/MT) & Driveline 2 10-02-2012 10:10 AM
New CV Joints or just CV Boots??? hellraiser Service & Maintenance 7 02-02-2010 10:07 AM
are jdmV7 cv boots=usdm sti cv boots?(rear) kharris4 Transmission (AT/MT) & Driveline 0 08-17-2005 05:59 PM
Question About CV Boot / CV Joint antidote11 General Community 6 04-10-2005 08:16 PM
time to replace CV joint and Cv boots.. SubaruImpreza_power Service & Maintenance 14 10-02-2003 10:13 AM
