Old 11-12-2000, 10:56 AM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Question Sorta OT: Need to buy torque wrench, recomendations?
Hey, I want to buy a good solid torque wrench with the widest possible uses. I don't want to buy one, to find out later that I should bought the other one. Should I buy a 1/4", 3/8", or 1/2". Anyone recommend a brand and where to get one(or are they all pretty much the same)? Also, what torque range should I be getting? 10-150ft-lbs, 30-200ft-lbs, etc. Thanks for all your help guys.
HomerJay is offline
Old 11-12-2000, 11:31 AM   #2
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
Goto harbor freight and get a torque wrench with a 1/2" driver (goes up to 500+ lbs). It's about 20 bucks, I got mine on sale for 12. They are good tools for the money and they are lifetime warranty. If you get a torque wrench, remember to adjust it back to zero everytime you put it away. If you leave the torque wrench at a adjusted value, the wrench will become noncalibrated, and you'll have to send it in to the company or buy a new one.
WRXwannbe is offline
Old 11-12-2000, 11:42 AM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
Wink
That's a great idea, thanks! I have a harbor freights right around the corner from my house. I guess I can use that to open the rear diff on my car and check the levels also!
HomerJay is offline
Old 11-12-2000, 05:54 PM   #4
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Post
With tools you get what you pay for with torque wrenches it doesn't pay to go cheap.
Get Snap-On a 3/8 drive w/15 - 150# should get most jobs done expect to pay around $250
DonA is offline
Old 11-12-2000, 06:44 PM   #5
philrb
Member#: 2547
Post
My neighbor has a Snap-On....I've got a $59.00 no-name. We checked them against each other....both were the same at 20-40-60-80....above that they differed with his being somewhat higher at 100 and above.
This was done on a torque wrench calibrator.
We couldn't believe the results would be so close. His looks nicer.
philrb is offline
Old 11-12-2000, 09:26 PM   #6
BG5
Member#: 695
Post
any new calibrated torque wrench should be good -- as they age is when to watch out. At $20 for the Pittsburg/Harbor Freight wrench you can almost afford to buy a new one every year instead of paying the 25-60 bux to re-calibrate an old one.
BTW, I wouldn't use a torque wrench to open the diff plugs or do anything but torque down a fastener.
[This message has been edited by BG5 (edited November 12, 2000).]
BG5 is offline
Old 11-13-2000, 10:34 AM   #7
AWDrivin
Member#: 1687
99 2.5RS
Question
I've been looking into torque wrenches myself. I checked Snap-On's site and was discouraged by the big price tags, but I know you get what you pay for. I've mostly gone with Craftsman because of their quality for the price and lifetime replacement on the spot. I'll probably go with Craftsman 3/8" for $69.99. Most likely I'll get a Sears gift card for xmas that will help even more.
My question is concerning 3/8" vs. 1/2" - wouldn't the 3/8" be more versitile or would it be more of a limitation in the long run? Does anyone have pros/cons on this?
CDB
[email protected]
AWDrivin is offline
Old 11-13-2000, 10:50 AM   #8
BG5
Member#: 695
Exclamation
The last time I looked, Sears doesn't give you a lifetime warranty on their clicker style torque wrenches, only 90 days. No one does lifetime warranties on clicker wrenches. The beam style torque wrench is probably lifetime though.
BG5 is offline
Old 11-13-2000, 01:38 PM   #9
Rajah
Member#: 362
2006 WRX STi
WRB / Gold
Thumbs up
Head out to Sears and pick up one of their digital torque wrenches @$90. It sucks trying to read a dial when torquing down things in a tight spot (i.e. spark plugs). Money well spent!
Rajah is offline
Old 11-13-2000, 02:34 PM   #10
Big Tee
Member#: 1802
1998 Impreza RS2.5
Post
The problem Rajah relates is why the clicker style is my fave.
You dont have to see anything, just listen and feel.
About 3/8" or 1/2" drive. Depends on the size of the fastener you're torquing. Head bolts and the like, 1/2" might be preferable. I've heard that the use of adapters (3/8" to 1/2") can affect the accuracy of the wrench if there's slop in the connection, but I've never seen that tested.
FWIW
Big Tee is offline
Old 11-13-2000, 07:47 PM   #11
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
As for the versatility and accuracy.
I've used haror frieght torque wrenches for a couple of years. I've built and rebuilt motorcycle engines with them. They are not bad for the money. Especially if you work on motors occasionally.
As for the 3/8" or 1/2". Get the 1/2". You can get a craftsman adapter to convert to 3/8". Flex will be minimal and shouldn't reduce the accurace when using the adapter. Also the 1/2" is much cheaper. But at the same time it's a lot larger than the 3/8". so it's your call.
HTML code is On
Way OT: need to buy a couple suits in phx Matt_az South West Impreza Club Forum -- SWIC 9 01-25-2009 03:59 AM
HELP: Need to borrow torque wrench that can torque up to 181lb/ft psyber_0ptix Mid Atlantic Impreza Club -- MAIC 11 01-20-2006 02:42 PM
Ok to use torque wrench as main lugnut wrench? BurntJamb Tire & Wheel 15 07-02-2004 08:29 PM
sorta ot: where to buy plug wires? Blindeye_03 Normally Aspirated Powertrain 1 06-26-2003 11:36 PM
Way OT: need to buy a leisure suit / 70's disco attire BurntJamb Bay Area Impreza Club Forum -- BAIC 1 01-23-2003 06:21 PM
