Old 09-12-2003, 02:23 AM   #1
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Default BAD O2 sensor? How do you check?
So, if my car is running kind of poorly and fits some of the symptoms of a bad O2 sensor is there a way to check and see if that is the problem without just throwing down the cash to replace a part that might, or might not be bad?
My car has 104K on it. I bought it used about 60k ago and haven't put a new one on it.
Thanks
Jared
gtwagon941 is offline   Reply With Quote
Old 09-12-2003, 10:32 AM   #2
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Get a Haynes manual for your car, and get a multimeter. Test the sensor according to the manual, and determine if the sensor is good or not.
Also keep in mind, if the sensor has a true, honest problem, then it should throw a CEL...
DerFahrer is offline   Reply With Quote
speedo problems? How do you check it? Looking for a “official” check Psybin Mid Atlantic Impreza Club -- MAIC 15 12-14-2007 06:47 PM
How do you check if you need to align bore your block? Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-17-2005 10:53 AM
('93-'01) how do you check PMs? mhj Impreza Forum 2 06-12-2001 07:47 AM
how do you check private messages? Donnie General Forum Archive 1 05-24-2000 10:18 PM
