Old 09-12-2003, 11:23 AM   #1
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Default Is there a bracket that will work to fit WRX front calipers on a 96 Impreza rotor?
Is there a bracket that will work to fit WRX front calipers on a 96 Impreza rotor? Thanks.
rallynutdon is offline   Reply With Quote
Old 09-12-2003, 12:29 PM   #2
AKGC8
Member#: 1305
2000 Impreza
Why would you want to fit WRX calipers onto a tiny L rotor?
I don't think there is anything that'll do that.
AKGC8 is offline   Reply With Quote
Old 09-12-2003, 12:33 PM   #3
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yeah?
thats an odd request
the rs bracket is smaller but not small enough
Old 09-12-2003, 01:39 PM   #4
rallynutdon
Member#: 24568
1993 Impreza, WRX
[quote]Originally posted by Eby
[b]Why would you want to fit WRX calipers onto a tiny L rotor?
Because I rally the car, 15" tires are what's available in rally tires, stock alloy Subaru wheels are inexpensive, and I don't have the budget to spend $1000 (or whatever) on a complete brake upgrade. But I do have 2 pot Legacy turbo and WRX calipers. The Legacy calipers will bolt on but need to be rebuilt. The WRX calipers are much newer.
Old 09-12-2003, 01:51 PM   #5
linsavy
Member#: 11620
1997 GF4 -STiV3
Saab 93 TX sportcombi
98-01 RS rotors and 97-99 legacy GT rotors fit under 15" wheels. I think Legacy turbo and Legacy GT fronts are the same?? You could swap your WRX caliper onto the Legacy bracket and get some new RS/Legacy GT rotors - 10.7inch and you are good to go.
PS Cross posting is teh no no.
linsavy is offline   Reply With Quote
Old 09-12-2003, 02:04 PM   #6
AKGC8
Member#: 1305
2000 Impreza
Yea, just trade your WRX brackets to a 2.5RS or Legacy GT guy who wants to upgrade his rotors.
Old 09-12-2003, 02:17 PM   #7
rallynutdon
Member#: 24568
1993 Impreza, WRX
PS Cross posting is teh no no. [/b][/quote]
"teh"? I know, but I didn't know where to go and since no one seemed to be in Brakes after I posted there, I did
Old 09-12-2003, 03:22 PM   #8
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i have a set of rs brackets ill trade you
.. and rotors for that matter
shoot me a pm
Old 09-12-2003, 05:58 PM   #9
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
if i recall correctly there are sets of 15" wheels which will clear wrx 4piston calipers, but only just barely.
i believe one set is the raceline rl-7? 15x7
if that works, then could'nt you use the full sized wrx setup?
tony
tbd is offline   Reply With Quote
Old 09-13-2003, 10:58 AM   #10
Puckaveli
Member#: 1518
00 2.5RS
rally nut, do you have a single stage booster or dual? If it's dual change it and put on some Brembo RS size rotors with an aftermarket pad and you will be just fine. I have ridden in a 99 RS with the single stage and it stops just as well as the STi with its big Brembos.
Puckaveli is offline   Reply With Quote
Old 09-14-2003, 11:37 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
all you need is RS rotors, calipers, and caliper brackets, then you can clear 15" wheels, you don't even need the brake booster, i have one and have never put it on the car, the brake pedal feels great with GoodRidge lines and Motul RBF600 in the lines. I use axxis ultimate pads which are IMHO pretty damn incrediblen for a street/track pad. GOod luck, but you 1.8L rotors will not match up to anything else.
Jeremy
p.s.: since your car weighs about 200-300 lbs less than a GC/GM RS you won;'t have any issues stopping damn fast. as for what Puck said about stopping ass well as an STi, remember that the STi weighs in about 300-400 more then a GC RS...those brakes under and RS would be insane
fitting wrx front calipers to rear? dub c Brakes, Steering & Suspension 2 03-11-2009 01:09 PM
Is there a bov that will work on the wrx? Ntercooled Factory 2.0L Turbo Powertrain 34 07-18-2006 09:08 PM
Is there a DVD that will play .mpg or .avi files? Eric SS Off-Topic 20 12-09-2003 02:32 PM
Is there a place that will make a small run of chrome badges? Orson Interior & Exterior Modification 4 09-06-2003 11:53 PM
is there any turbo that will work with the hks d/p? 2002whitewrx Factory 2.0L Turbo Powertrain 12 02-04-2003 05:35 PM
Message Board Statistics All times are GMT -4. The time now is 06:27 AM.
